Results 1 to 5 of 5
Thread: E39 97 radio wont work
    Jun 2017
    New york
    E39 97 528i
    So i have a e39 97 bmw 528i i just brought it and the radio isnt workign i brought a new one and it wasnt the problem. Not sure what to do now anybody knows what coukd be the problem or any suggestions i really appreciate it
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    What is the problem? No power at all? Or is the radio code missing?
    Sep 2008
    West London/Heathrow - UK
    03 530dT - Ex Police Car
    Hi,
    Welcome to the forum firstly!
    There's not enough information to help you just yet. Plus, it's not possible to give you a definitive answer as no one here can see your car.
    When you say you purchased a 'new radio' .. exactly which one did you buy? which 'radio' was in the car when you purchased it? I suspect from what you're saying it's an aftermarket head unit? if, so you'll need to check the wiring of the car to ensure it's functional and correct i.e ensure there's a working +12V, switched +12V, earth, speaker wires are all intact etc etc. If you have an OEM radio, then the same for that as well, also if you purchased a 'used' OEM unit, it might not be working so you'll need to source a known working OEM unit that's the correct one for your early 97 E39 - there are differences.
    Do take some clear pictures of what you have as well?
    There's also plenty of auto electricians in NY who could look and do the testing of the correct power/ground cables etc and then wire in the replacement radio or aftermarket unit etc.
    Cheers, Dennis!
    Dwin is offline Go Big or Go Home......
    Sep 2013
    Groveland, Florida
    98 528i
    Quote Originally Posted by DennisCooper View Post
    Hi,
    Cheers, Dennis!
    The one and only audio guru has spoken!!!
    [/IMG]
    San Jose, CA
    1997 BMW 540i 6 speed
    The only easy way to troubleshoot this is by substitution. But, you need to be sure that you have the correct component.
    Dennis, I laud your patience!
  1. wipers and radio wont work E36
    By Bimmer M3 in forum 1991 - 1999 (E36)
    Last Post: 09-08-2012, 06:09 PM
  2. Bmw E39 key fob wont work...
    By carino in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-20-2011, 02:49 AM
  3. radio wont work at all
    By is709 in forum 1999 - 2006 (E46)
    Last Post: 07-29-2010, 07:53 PM
  4. Radio WONT WORK!!! HELP!
    By rastayute in forum 1996 - 2003 (E39)
    Last Post: 05-14-2007, 12:33 PM
  5. 3 spoke steering wheel installed now radio wont work
    By ///Mpmp1025 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-16-2006, 01:30 AM
