Results 1 to 4 of 4
Thread: Driveshaft separation
    May 2015
    Oregon
    1995 BMW M3 Coupe
    Hey guys,
    Working on replacing my center support bearing right now. Got the guibo and everything disconnected but now I'm stuck at the separation point between the front and rear driveshaft. It doesn't look like anything posted online for the e36 m3. I've attached pics below. Any idea of how to get these two apart? The old CSB is still wrapped around this as well, regardless there should still be a way to pull it apart. Thanks
    PS this is a 6 bolt CV driveshaft if that helps at all.
    "Mini cupcakes? As in the mini version of regular cupcakes? Which is already a mini version of cake? Honestly where does it end with you people." -Kevin Malone
    ///M
    Jun 2016
    North Carolina
    03 525it/5, 1967 GTO
    There's an 18mm bolt that connects the joint flange to the forward shaft just to the rear of the CSB. The lighting in the photo is bad but you can see it in your second photo to the right inside the u joint flange. Remove this bolt (I think you need a 12 point box wrench) and you should be able to separate the two. You might need a gear puller to pop it out of the old CSB.
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    STOP!
    Before you proceed, mark the sections before and after the slip joint with paint.
    The u-joints fit into yokes. One side of the yoke is fixed to the shaft, the other side has splines that slide into the section that the center support holds up. Remove the bolts that hold the driveshaft to the diff and the trans, and drop the center support bracket. The u-joint next to the center support can be separated from forward section of the drive shaft so you can get the center support bearing off. YOU MUST MARK BOTH HALVES OF THE DRIVE SHAFT BEFORE YOU SEPARATE THE SLIP JOINT SO THAT YOU CAN REASSEMBLE THE SLIP JOINT SO THE SHAFT REMAINS BALANCED AND THE YOKES REMAIN IN PHASE. You should also mark the orientation of the shaft to the differential and the transmission so you reassemble the parts in the same orientation.
    May 2015
    Oregon
    1995 BMW M3 Coupe
    Quote Originally Posted by Twistytee View Post
    Got everything off and replaced after working on that 18mm. Thanks!
    JD don't worry I marked everything. It's backed together running smoothly. Thanks also.
    ///M
  1. how do I separate a euro driveshaft?
    By sidewayz328is in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 05-15-2009, 07:54 AM
  2. Is the driveshaft separable?
    By todor in forum 1975 - 1983 (E21)
    Last Post: 08-02-2008, 05:09 AM
  3. how to separate the driveshaft?
    By tortexal in forum 1988 - 1996 (E34)
    Last Post: 06-26-2008, 01:24 AM
  4. how to separate driveshaft
    By LukeSkywalker in forum 1991 - 1999 (E36)
    Last Post: 06-15-2008, 10:05 AM
  5. Separating Driveshaft from Diff Flange?
    By ggantt in forum 1992 - 1999 M3 (E36)
    Last Post: 01-22-2006, 04:02 PM
