Results 1 to 4 of 4
Thread: 318ti dash into e36 m3
    Sep 2016
    Long island
    E46 M3. 6spd. Coupe.
    Anyone ever do this swap?
    Really dont like the 90s vibe of the m3 dash and like the simpler 318ti dash.
    ive seen m3 dash into ti but never the opposite.
    any insight?
    Gonna start the swap soon so any help appreciated
    will post updates once started
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    In a car, the goal of the driver is to get as much information as is possible. then act on what you gather. Taking the M3 out and putting the 318ti in is a giant leap backwards. If it is true that you have seen an M3 dash installed into a ti, then it holds true that the ti dash should fit into the M3. The question becomes, why would you do this?
    The Tach will be calibrated wrong, although that should not be difficult to resolve. I think the M3 gets a gauge for oil temp and pressure, the ti has a dummy light for pressure only. The tach and speedo go to higher numbers than the ti goes to.
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    I think he is talking about the whole dashboard, not the gauge cluster but I could be wrong.
    Connecticut
    '98 ti (M powered)
    I think if you have a sedan it may be easier but I had read about one swap into a ti where it was not a pleasant experience.
    And the cluster stays with the engine. I run the M3 cluster in my ti to look after the S52. I wish I had an oil temp gage...
  1. V8 into e36 m3? Anyone on the boards done it before?
    By yellowbullet in forum 1992 - 1999 M3 (E36)
    Last Post: 04-10-2005, 10:53 AM
  2. E46 M3 Engine/SMG tranny into E36 M3...
    By Alpine323is in forum 1991 - 1999 (E36)
    Last Post: 02-20-2005, 06:44 PM
  3. Looking into E36 M3
    By AtlanticVortex in forum 1992 - 1999 M3 (E36)
    Last Post: 08-22-2004, 08:14 PM
  4. Feasability question: US market 540i six speed trans into E36 M3
    By HellRotCoupe in forum 1992 - 1999 M3 (E36)
    Last Post: 03-20-2004, 10:44 AM
  5. 318ti Dash Swap(will M3 2 door fit?)
    By Dakar95M3 in forum 1991 - 1999 (E36)
    Last Post: 05-02-2003, 04:06 PM
