Just bought a 1998 750iL 120K car. Besides the fact that I can't talk to either of the DME's with GT1-DIS or INPA, I am able to talk to the EML. There were no errors, but there is a weird problem when driving.
When accelerating, if you use more than about 1/2 throttle, it's as if someone turned off a switch. The engine Just stops pulling and the car slows. If you back off the throttle to less than 1/2, it will pull hard. WTF? I suppose my biggest fear is the EML's need rebuilding (groan), but I'm open to any other ideas as well.
I have no idea where to even start with this. Nor do I have a clue as to how to get communication with the DME's
Any suggestions or ideas would be helpful.
Mike Drives:
BMW's
E24 - 635CSiA - (1) 1985 (US)
E24 - 635CSi - (1) 1985 (EC)
E31 - 850iA - (1) 1991 (Black)
E31 - 850iA - (1) 1991 (Calypso Red)
E32 - 740iA - (1) 1994
E32 - 750iA - (1) 1990 (Not an "L") (EC German National)
E32 - 735iL - (2) 1990
E32 - 750iL - (1) 1990
E38 - 740iLA - (2) (1) 1997 & (1) 1998
E38 - 750iLA - (1) 1998
E38 - 740iA - (1) 2000 "Short Sport"
E39 - 528iA - (2) - 2000 & (1) 1997
Also:
2015 Ram 3500 Dually, Cumins 6.7, Std.Cab. Long box 4x4 (To haul all this junk when necessary)
2014 Dodge Dart Rallye (Daily Driver)
2007 Mercedes Benz CL600 (Brabus SV12S)
Mercedes Benz SL's - (1) (2002) & (1) 1999 500 - (1) 1999 600
1967 Buick Riviera (2)
recalibrate the EML
If you mean re-sync the EML's, I already did that (I think). That was first on my list though I forgot to mention that (apologies). Disconnect battery, let stand for an hour, re-connect, idle 5 minutes, 1st gear, up to 5000+ rpm, back to idle, rinse and repeat 2 more times, idle 5 minutes - Voila! No joy!
Also: Spaced out on EML errors in INPA, received the following:
EML3 Error
These look like bus errors regarding communications with the exception of 153, but I have no idea what stepper motor it's referring to. EML motor?. Could this be an issue in operation? Need translation.
81 – DME_R2, DME_L2, EGS, ASC CAN Error Receiving Data 106 – Error In Data Exchange During Normal Operating 153 – Error Diagnostic of Stepper Motor IC
Thank you
Mike Drives:
BMW's
Also:
ryanpeter;
What?
Mike Drives:
BMW's
Also:
