Results 1 to 4 of 4
Thread: Billet flexplate
    Aug 2013
    Jupiter
    m3
    Billet flexplate
    Looking for a billet flexplate for E36 / E46
    to be used on TH400 / S54
    Aug 2012
    CT
    Twin turbo LS E36 M3
    The point of a flex plate is to be able to flex with converter growth. Im not sure you'd want a billet unit
    but talk to tci or someone that makes a sfi plate and see if they will sell you a blank unit
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
    Apr 2006
    Minnesota eh?
    86 325es
    The pilot diameter in the crank is also wrong for a th400 converter pilot. So you either need a custom converter with a special pilot or an adapter. This is what I worked out for mine.
    This uses an off the shelf chrysler hemi flexplate that has the bolt holes for a chevy converter. The crank adapter has the correct pilot diameter for a GM converter and the depth is also correct so I won't need a special converter. I wanted to be able to use any th400 converter without having to have a custom pilot. The first adapter plate and crank adapter is at the machine shop being cnc'd right now. I have someone else interested in getting another one made so if you are interested I can get a couple more made.
    Aug 2012
    CT
    I was looking at my TCI plate yesterday and the middle is an adapter. So you could essesentially get a blank, and it would have a larger center whole that you could make an adapter with.
  1. Auto Flexplate instead of billet flywheel for 5.5 race clutch???
    By raamaudio in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-29-2012, 10:32 AM
  2. Legend 5 Billet Kit
    By Uber328 in forum 1991 - 1999 (E36)
    Last Post: 09-04-2002, 02:02 AM
  3. Billet Auto. Shifter
    Last Post: 08-13-2002, 01:04 PM
  4. Replies: 1
    Last Post: 10-13-2001, 06:53 AM
  5. Billet Aluminum Door Sills
    By Esteves in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-21-2001, 12:59 AM
