Results 1 to 11 of 11
Thread: E36 analog heater to analog heater with climate control
    Dec 2015
    Lithuania
    318i sedan & 325i coupe
    Cool E36 analog heater to analog heater with climate control
    Good day petrolheads. I was searching all overl the internet but only seen people interested in swaping analog to digintal climate control, but I'm more interested in analog with climate control (hoping it will be less work than swapping to digital) So have anyone done that before or could link me to a DIY? Thanks
    From this:
    To this:
    Oct 2013
    The Netherlands
    2011 E90 325xi
    If I'm not mistaken the conversion is not more simple. You will still need a different unit behind the dashboard controls which is electric as well. In my eyes there is no difference in difficulty between the one you're planning and the full electric climate control
    The Netherlands
    DE-spec E36 328i/M3 cab
    Indeed. Both options go from single temp zonde to dual zone, so need a heater core with 2 radiators in it. Although technicall, you could hook up only one side.
    And if you need to swap heater core, might as well go digital. Which will work fine without A/C.
    And that's your hardest part, regardless what version. If you want A/C, you need the pump, dryer, condensor and all lines.
    IG:
    Dec 2015
    Lithuania
    @MParallel thats an interesting idea about hooking up only one side, think it would work? For that I could only swap the units (plug&play)?
    Apr 2014
    UK
    1995 BMW 328
    If you only hooked up one side of the heater / AC unit you could only heat or cool half your air flow.
    If you used a dual zone panel with standard heater unit you don't have the AC components inside to cool.
    To be fair the dual zone feature isn't much good when the passenger compartment is one airspace.
    No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
    Trumbull CT
    1998 M3 Vert, 1992 318i
    Quote Originally Posted by E36328Coupe View Post
    Dual zone is phenomenal. I prefer it cooler than my passenger 90% of the time, and the dual zone lets that happen. Sure you get some mixing, but they can have the heat blasting and I might be warm but at least I'm not sweating.
    Caprica Junkie
    Apr 2014
    UK
    1995 BMW 328
    That's ok if 3 degrees is enough https://www.bimmerforums.com/forum/s...limate-Control
    My 328 has it and it doesn't allow enough difference to notice
    The Netherlands
    Dual zone works just fine.
    Wat about these cars with 4 zone climate controls then...
    IG:
    Apr 2014
    UK
    1995 BMW 328
    Mate's had over 10 E36s and he doesn't rate it either, so not just me or the guy(s) on the thread I linked, or a particular car. And finally it was that good they abandoned it for the E46 I think. However, each to their own
    The Netherlands
    Let me get my mates who all love it.
    E46 thing is pointless. After the E46 and all models after, all got dual zone in front back. But each to their own.
    Maybe they all didn't work 100%.
    IG:
    Apr 2014
    UK
    1995 BMW 328
    If it truly does only allow 3 degrees variation that's not enough to bother with the complexity.
    However, the best solution is it's my car so the heater stays how I put it
  1. New to e36's, need to make sure with you guru's.
    By Genkiboi8o8 in forum BMW Rides & Events
    Last Post: 08-26-2016, 09:30 AM
  2. E36 E36 ///M tri-spoke steering wheel - with audio controls
    By 97flgst in forum Interior Lighting & Body Parts
    Last Post: 07-18-2013, 05:31 PM
  3. E36 Problems with climate control
    By ctoddkc in forum 1991 - 1999 (E36)
    Last Post: 06-20-2013, 12:02 PM
  4. e36 m52b25 stroked to 2.8 with itb's and turbo
    By m52 in forum Forced Induction
    Last Post: 03-07-2006, 02:22 PM
  5. Trouble with Climate Control
    By Essex502 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-15-2003, 09:14 PM
