Results 1 to 16 of 16
Thread: 03 540i odd issues
    Aug 2014
    Wichita Kansas
    1993 BMW 740il
    03 540i odd issues
    So I have had a 93 740il for a couple of years now and I ha a friend leaving to be deployed and he offered me his 03 540i M Sport (it's a real one) for $1500 so I got it he aid he thought it needed a alternator and a break line was broken. The car hadn't been moved in 8 months so I charged the battery went to jump it all the lights were on and then nothing so I did the touch the wires together thing and when I reconnected the battery the nav screen pops up a code and a 10 minute count down I didn't know the code so I let it count down. It finished and the car started and drove fine. But then a few days later I noticed the turn signals worked on the outside of the car but didn't indicate on the dash when the headlights and fog lights are on the indicator in the instrument panel didn't show a light anymore but after sitting overnight it started working again. The windshield wiper switch does nothing at all noticed that in a downpour and barley made it home... also the nav screen goes on and off while driving constantly resetting itself none of the functions work on it but the right knob it let's you go through the car data and stuff the but the code one is greyed out. Also sometimes all are greyed out. Also the interior dome lights don't work I've checked all the fuses and they all seem to be there. Also it does the shutdown thing asking for the code probable once every other day. I now have the code so when it does it again I'm going to put it in and see what happens but does anyone know what could be the problem with this I've looked through forums that said they useing the visor it doesn't do anything to the radio or steering wheel when I try them. Anyone I'm confused AF and not starting to think the deal I got wasn't that good.... any help would be lovely please!
    Last edited by JimLev; 06-24-2017 at 07:53 AM. Reason: corrected typo..(no profanity) changed to shutdown
    Mar 2017
    Lake Goodwin, Wa
    1997 540I 6 speed
    I would start with ensuring the charging system is working. Charge the battery fully. Let the car sit a few hours and check the voltage. IT should be 12.4-12.5
    IF its up to snuff then check the voltage while driving. you can access the high obc and monitor it while driving(do a search on obc hidden function).
    A lot of funky electrical issues can be caused by a lack of power.
    2001 Ford Lightning - Built Motor - Built Trans - 2.3 KB - Custom Interior - 537/632 - 11.40 @ 119.6 - Garage Queen
    2008 F-250 - Tune/Delete/Studs - Lifted - BroDozer
    1994 Cobra #2277 of 5009
    1993 Gen 1 Lightning #5194
    1968 Ford Mustang "Gold Nugget Special"
    2015 Chevrolet Tahoe LTZ
    2015 Hyundai Sonota Sport
    1997 BMW 540i
    My Youtube
    Aug 2014
    Wichita Kansas
    1993 BMW 740il
    I did a check it pushing about 13.4 volts sitting with the air on haven't tried it driving yet
    Mar 2017
    Lake Goodwin, Wa
    1997 540I 6 speed
    That's a bit low, but not the worst.
    1997 BMW 540i
    My Youtube
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    13.4 is fine.
    Mar 2017
    Nowhere
    something
    Have you checked the infamous E39 water reservoir, the one under the passenger seat. It is known to cause all kinds of issues.
    Jan 2016
    Ca
    2001 525it
    Ignition switch
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Quote Originally Posted by Uturn540 View Post
    Quote Originally Posted by jclausen View Post
    Ignition switch
    I like both of these suggestions, although the first the most.
    OP - read up on water getting into the floor of the car and causing all kinds of problems.
    Also minor thing but... friendly suggestion: try using the 'enter' key sometimes and making paragraphs in your posts. Lotta guys won't even read your stuff when you type BLAHBLAHBHABLAHBLAHNOPARAGRAPHS100SENTENCES.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Maybe that's just how he speaks...
    Apr 2015
    United States
    1999 BMW 528i E39
    Sounds like the ignition switch. Might wana start there
    Oregon
    '99 528i/5, '01 Boobaru
    Rkeondre, if the car sat that long without the battery being kept charged (trickle charger, battery tender), the battery might have sulfated enough to have dead cells. Find out how healthy that battery is. If it's in poor shape with any bad cells, it won't have enough amps to power everything even if it shows a good reading on a multimeter.
    Not only that, but if the alternator is constantly trying to keep that battery charged, you'll see a low voltage reading with the car running. This can eventually kill the alternator because it's not designed to be charging a low battery. 540i alternators are not cheap.
    Aug 2014
    Wichita Kansas
    1993 BMW 740il
    What do you mean by the water reservoir I've searched for it and can't find anything???
    Also I put a brand new battery in it the battery is fine and I know I already bought another alternator I just haven't put it in because it doesn't seem to be the problem. I'm going to buy a ignition switch Monday and see what happens.
    Another thing what are your guys thoughts on keeping the stock widescreen gps or getting a aftermarket one?
    Mar 2010
    Water reservoir is Uturn's joke. It means there are 2-3 ways water can fill the floors under the carpet and cause all kinds of really weird and effed up hassles.
    2003 M3CicM6 TiAg
    Former:
    Mar 2017
    Nowhere
    something
    What geargrinder said, There is a fuse panel buss under the carpet under the front passenger seat. It is recessed below floor level and any water seeping in will end up submerging the area. Check out this thread, especially post #16
    https://www.bimmerforums.com/forum/s...ght=fuse+water
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    On enter-code thingy, you need new GPS unit
    Instagram.com/nordmanmg
    Your current situation is not your final destination
    Santa Cruz Mountains
    '03 M-Sport 540iA
    My vote is for a ground block short (time to start checking the wire looms). From what I've read, sometimes the solder points will get loose over time and cause these kinds of odd, intermittent electrical gremlin issues...
    EDIT: As for the wiper issue, treat your windshield with Rain-X or my preferred treatment, Rain Clear by Glass Science. The awesome thing about this stuff is that it can also be used to refresh the non-glossy trim on the door pillars/windows and around the sideview mirrors...
    '00 540iA Sport w/235k+ Original TCG's, Vanos and transmission.​*Trans failure at 244k+...FS Now
  1. '03 540i M-Sport Radio & Navigation Issues
    By FUN M3 in forum 1996 - 2003 (E39)
    Last Post: 03-12-2014, 12:00 PM
  2. Couple issues with my 03 540i sport 6spd
    By E46MD in forum 1996 - 2003 (E39)
    Last Post: 11-02-2010, 12:49 AM
  3. 98' 540i ODD STARTING ISSUE
    By charmersfh in forum 1996 - 2003 (E39)
    Last Post: 03-20-2009, 12:05 AM
  4. 540i Headlight issues...
    By E39540i6 in forum 1988 - 1996 (E34)
    Last Post: 09-29-2003, 05:58 PM
  5. '03 Lincoln LS handles better than the '03 540i????
    By luckee2bhere in forum Off-Topic
    Last Post: 08-26-2003, 06:38 PM
