Has anyone ever had an issue where their passenger window goes halfway up then starts to back off so you have to click the button over and over to get it to go up the rest of the way? Would this issue be the regulator or motor most likely?
https://youtu.be/i0TwcDtgdls
Sent from my SM-G955U using Tapatalk
I have the same issue on the driver side in my vert. I still haven't figured it out, I have a feeling it's the window position sensor. I already tried swapping buttons and nada.
Yes I have. I think on both windows now on the coupe. As noted above I think it means the motor (at least the counter/position part of it) is starting to fail.
98 328is
02 525ita
80 528i
81 528ia
and decades of owning and driving BMWs
If you have one touch close and have done the procedure where you wind the window up and hold the up button to learn the top stops but it still intermittently stops and backs off like the anti-trap function has activated I solved this on my coupe by setting the anti-trap settings to those of a saloon or compact, because that allows for slightly higher resistance before activating the anti-trap.
No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
Yeah, that's not the issue. It's got to be motor or micro switch related
16 - 20 pin adapter
vag com / obdII / KKL cable (FTDI 232RL chipset if USB)
NCSexpert read the trace
Open the trace with NCSdummy
Set the anti-trap
Save as .man (dummy will do it for you)
Use NCSexpert to write it back
I expect it is not a micro switch because the problem can be fixed in software (if like mine) it must be measuring a resistance or load
With the OPs video once above the sticking point it goes up one touch, that was what mine were doing.
Doesn't have to be you get about 80% of modules with the stuff I said above anyway, including the body control module. You wouldn't buy the 16-20 pin adapter if you had the OBDII socket under dash.
Unless yours doesn't have a ZKE - I don't know older than our 94 and 95 325 and 328 respectively
Some reading http://www.bimmerforums.co.uk/forum/...lained-t85191/
