Results 1 to 7 of 7
Thread: Source for E24 Foam Underflooring?
    Mar 2012
    Farmington, CT
    1988 BMW 635
    I'm not sure what the proper term is but the foam underneath the carpet was soaked and falling apart. Is there any third party source for the E24? If not, what materials should I track down and where should I look for it? I've finally fixed this '88 after 5 years and I can't wait to put it all together, the foam is the biggest obstacle right now.
    Aug 2014
    Lutz, FL
    '85 635 CSi Euro 5sp.
    Are you looking for something that's concours-correct, or something that is better than original? If the latter, there are lots of choices, but I like FatMat:
    http://www.fatmat.com/shop/75-sq-ft-...included-26112
    Dean
    Lutz, FL
    '85 635 CSi Euro #9402254
    '87 Spider Veloce
    '92 Spider Veloce
    '08 350Z
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    I used 3/16" neoprene over 1/2 foam. If you look at yours you will see that is pretty much factory
    81 Euro undergoing total nut and bolt restoration
    pictures at: flickr.com/photos/bertsphotos
    Anacortes,WA
    E34 535i; E36 325is
    Look into Frost King heating duct insulation from Lowe's or Home Depot, about $1/square foot for a 15" X 15' roll. This is aluminum foil backed adhesive foam about 1/8" thick and is designed to insulate heating and air conditioning ducts as are common in attics, etc. Dampens noise about as well as Dynomat and its competitors, for a fraction the price and weight. Conforms well to shapes such as car floorpans and roofs. Waterproof. Seal edges with aluminum foil tape (much like duct tape) and it's waterproof. Thin enough to fit between door cards and the door sheet metal, so soundproofs doors, too, and sunroofs, underside of hoods, etc.
    Sep 2016
    North Florida
    1983 633csi, 2017 540i
    I have used frost king beneath rear seats, doors, and trunk. About $100 to do all that. Made a noticeable difference.
    Mar 2012
    Farmington, CT
    1988 BMW 635
    Frost King and Fat Mat look like great alternatives. I'm going to take the interior out completely first and remove all the adhesive and rust spots
    Savannah GA
    '73 ///M2, '85 ///M635
    You may want to research further on what products to use to mitigate rattles vs. road noise. I think the Frost King stuff is more suited to minimize the former. But I'm far from expert.
    Cheers,
    Ray
  1. Source for thin acoustic dark foam for speaker grills backing...E34 rear for example
    By M3 Euro LTW in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-21-2013, 08:05 PM
  2. Best source for '89 e24 replacement air dam?
    By 6gun in forum 1976 - 1989 (E24)
    Last Post: 03-02-2011, 07:52 PM
  3. E24 set of four 18 x 8.5 et 13 bbs rk for e24 6er
    By 03msport540it in forum Wheels and Tires
    Last Post: 12-08-2009, 09:57 PM
  4. Source for magnetic auto-x numbers
    By ialevy in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-29-2001, 04:59 AM
  5. Need source for Hawk Pads Soon!
    By John (PA) in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-18-2001, 03:57 PM
