Results 1 to 18 of 18
Thread: Bimmerworld Oil Diverter Valve Problem
    Nov 2008
    Hillside
    Integra GSR
    Does anyone have experience with Bimmerworld Oil Diverter valve? So I got the valve today and saw there are attached shaving from bad machining. I was told to try to fix it, and since I don't have precision tools to fix this, can someone give me some ideas? I am going to use a drill bit the size of the little dip that is in there, but I am pretty sure my vise will damage this since this is soft aluminum. A little sad I paid $60 for this kind of quality.. But anyways, what is a good way to clean that up. I don't want those shavings falling into my S54 motor when it gets softer with oil temp. Thanks. -Wen
    Oct 2003
    Seattle
    99 M3
    You should be able to knock that 'bur' off with a drill bit slightly larger than that drill start. Optionally, use some medium grit sand paper to clean it up.
    Nov 2008
    Hillside
    Integra GSR
    Thanks. Tried with sandpaper and used a punch to rub it. The burrs that are left are a little too bent for the sandpaper to take off. I was going to use a drill bit but afraid of the piece catching the bit and get messed up since I won't be able to hold it once it catches. Someone mentioned a dremal. I'll ask around to borrow one.
    Wen
    Someone on m3 forum mentioned that part doesn't touch oil. Is this true? Anyone have pictures of this installed?
    Apr 2013
    Alabama
    1995 M3 Coupe
    Even if it does touch oil, those aren’t going anywhere IMO. But I feel ya, peace of mind and all. Go with a drill bit
    1995 M3...Screwed
    Charlotte
    2012 GTI
    I would suggest a round file, not unlike a chainsaw file though they do make larger ones. The flat end shouldn't cause any damage to the dip area, and can clear up the rough edges.
    97 M3 - SCCA TT Prepped
    17 F150 - Tow Pig
    05 S2000 - Sold
    88 325is - S52 powered - Sold
    95 M3 LTW Rep - Death by Altima
    Nov 2008
    Hillside
    Integra GSR
    thanks
    Quote Originally Posted by matthugie View Post
    Richmond, VA
    E82 128i, E36 M3
    Did you contact Bimmerworld and ask about exchanging it for one that doesn't have those rough edges?
    Nov 2008
    Hillside
    Integra GSR
    Yea. Called bimmerworld and John Webb said just try to fix it since their current stock is all the same. Should have gotten this from eBay for $20 instead paying $60. Got suckered with the cooling discount deal there thinking paying top dollars means good quality product. That whole paying more for good quality saying is definitely not true.
    Richmond, VA
    E82 128i, E36 M3
    It was worth a shot. I don't think those pieces would be an issue but it's an easy fix. Drill bit, round file, something long and round (like a 6" 3/8" socket extension) with some medium sandpaper taped to the end, etc would clean that up easily.
    Nov 2008
    Hillside
    Integra GSR
    Thanks. I'll try not to mess it up.
    Quote Originally Posted by hoki06 View Post
    Sep 2013
    North Texas
    2001 MCoupe
    Totally worth cleaning it up and getting it installed. Without it I had to run the heater full blast to keep oil temps in control on any track day >80*. Now temps stay rock solid, even on 95* track days.
    2001 Steel Gray MCoupe - 147,000 miles and owned since new. MCS 2WNR suspension, Hotchkiss swaybar, poly bushings all around, cat delete headers with custom tune, 3.73 LSD, and Clownshoe Motorsports rear subframe reinforcement.
    2014 Porsche Cayman S / 2022 BMW X3M Competition / 2020 Ram Rebel
    Nov 2008
    Hillside
    Integra GSR
    Thanks! I hope I don't mess it up. Delicate metal work isn't my thing.
    Quote Originally Posted by Bobkid View Post
    Feb 2009
    Mountain View, CA
    06 GTO, e36 race car
    Try using the drill in the reverse direction so it doesn't bite into the material. The correct-sized drill should knock those bits off.
    Oct 2003
    Seattle
    99 M3
    Or with a larger bit by hand…
    Jan 2006
    Gateway To The West
    2001 BMW M3
    Gents:
    My oil diverter valve arrived from Bimmerworld yesterday and it's perfect.
    Feff
    Nov 2008
    Hillside
    Integra GSR
    I was told all of them are the same... I am a bit upset... I tried drill bit and files, the big piece won't come off clean..
    I finally got it fixed with dremel... And that is $25 later... This is just doesn't feel good.
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    Quote Originally Posted by wenlyone View Post
    This is the best thing you could do about it, let the community know and we get to see if they step up to the plate...
    There is a lot of purchasing power on this board, I can promise you.
    Nov 2008
    Hillside
    Integra GSR
    It's alright. I fixed it. I reached out and they said cause this was purchased with the cooling discount this month, there is nothing they can do about it. So I guess if we buy during sale time, it's ok to get sub standard parts. Pretty sure the guy who just got his perfect valve used the coupon too.
    I bought all my parts from them through out this past 3 years, regardless how their price is more than tms or ecs. But I guess that doesn't matter. Oh well. Not a big deal. Just wasted a few dollars and time.
  1. e36 oil diverter valve install
    By reno5658 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 09-08-2014, 02:18 PM
  2. Air Injection Valve or Oil Separator Valve Problem?
    By blackhawk51 in forum 1999 - 2006 (E46)
    Last Post: 07-19-2011, 10:37 PM
  3. oil seperator valve problems
    By postman1 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-28-2008, 05:29 PM
  4. oil seperator valve problems
    By postman1 in forum 1983 - 1991 (E30)
    Last Post: 01-28-2008, 12:35 PM
  5. oil seperator valve problems
    By postman1 in forum 1999 - 2006 (E46)
    Last Post: 01-28-2008, 04:32 AM
