Page 6 of 9 FirstFirst 123456789 LastLast
Results 126 to 150 of 221
Thread: Colton's $38 per Cylinder Restoration: A Probable Financial Disaster
  1. #126
    Aug 2015
    Oconomowoc, Wisconsin
    01 750il, E38/9 Parts
    One more thing, after clearing codes, P0740 has not come back, which makes it seem it was a fluke, especially, since the TC seems to lock and unlock as one normally would.
    --- 750il Maintenance/Restoration Thread --- E38/9 Parts Cars --- YouTube Channel ---
  2. #127
    Aug 2015
    Also, my wood trim project is going along, sort of. I got my test piece fully stripped, sanded, and stained with Zar's Black Oynx, and have to say, it looks great. I also tried VHT Engine Enamel Clear on it, mainly because I was impressed by the hardness of the finish on my brake calipers. The finish isn't coming out particularly well, even with sanding, so I think I will go to a brush on spar urethane. I will get pictures of how it looks compared to stock trim color in the daylight.
    The main drawback is the stripping, this single e39 center console took about 10 coats of aircraft stripper, and nearly as many hours of work to get where I am today. I don't have the sanity to do that for 20 or so pieces. I'm gonna see if I can find a good container to put them all in, and just let it all soak in stripper, and hope that works.
  3. #128
    Aug 2015
    part 740il 750il
    Subframe Same same
    Swing Arm same same
    Integral link same same
    front suspension link same same
    Wishbone same same
    Carrier same same
    Hub same same
    Sway bar same same
    Output shafts (different pn's, should both be 94mm) 33211229214
    Guibo same same
    I'll add more to this list if needed, but it looks like there should be no problem. The one questionable thing is the driveshaft, they won't swap due to the 5hp30 being slightly longer than the 5hp24, but if for whatever reason the 750 driveshaft is a different size than the 740 diff input shaft, I could make a frankenshaft using the first half of the 750 shaft and the rear half of the 740 shaft, but I don't forses that being needed. This might be easier than I had originally anticipated.
  4. #129
    Aug 2015
    Updated my sig, about damn time.
  5. #130
    Aug 2015
    I found out that even without the rear coils on, I scrape driving out the bank driveway, so now I need to street park and walk in like a peasant
    Sent from my Nexus 6P using Tapatalk
  6. #131
    Aug 2015
    Got Sofie's subframe mostly dropped. I was hoping that I could do it without completely unbolting the exhaust, which obviously was wishful thinking, so I'll drag out the sawzall tomorrow and chop it out. Completely forget about the parking brake line, so I need to disconnect that. Once I cut out the exhaust, I should be able to lift up the car and have real easy access to the driveshaft
  7. #132
    Aug 2015
    Also, even with welding gloves on to clear up this mess, I still managed to get a couple glass splinters :/
  8. #133
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    Quote Originally Posted by ColtonBH View Post
    You use vacuum cleaner to lift that up
    Instagram.com/nordmanmg
    Your current situation is not your final destination
  9. #134
    IL
    2000 740i sport
    What happened? Dual pane windows broken?
  10. #135
    Aug 2015
    Quote Originally Posted by purplecty View Post
    This is in my old 740il, the one that I'm borrowing parts from. The wheel bearings, and suspension in general are much better on it, so it's getting swapped from Sofie to my 750il
  11. #136
    Aug 2015
    Quote Originally Posted by NordmanMg View Post
    2:00 am when I did it, can't be waking everyone up with loud stuff
  12. #137
    Aug 2015
    Put an OEM battery in out of my 740il, I'll leave it on a trickle charger for the next couple nights, but I'm getting 13.9-14.1v on the dash, so I think I'm golden as far as electricals goes
  13. #138
    Jul 2017
    Miami, FL
    2001 BMW 750iL
    Congratulations buddy! I just picked up mine 3 weeks ago but not for such a great steal like you lol i paid after title transfer and tag $2800 and i just tonight finished putting in both brand new BMW 70ah and 110ah batteries. Took me about maybe 30/45 mins to learn it all and get it all buttoned up with still some codes and running very rough but i am working with her. Definitely subscribing to the build thread but post pics also lol i want to see the diff swap.
  14. #139
    Aug 2015
    Quote Originally Posted by MrRockaV12 View Post
    I need to get better with posting pics for sure. My diff swap will be different than most, because I am moving the whole subframe from one car to another, but I'll still show pictures
  15. #140
    Aug 2015
    Get your own thread going as well!
  16. #141
    Jul 2017
    Miami, FL
    2001 BMW 750iL
    Oh dont you know it! Once i really start going at it then i will but for now she just sits and waits for me patiently to gather the money up so i can spoiler her.
    Looking forward to the pics though dude lol
  17. #142
    Aug 2015
    Hood latch is fixed (sort of), bumper is back on, and I cleaned out the wheels. Just need to find a day to swap out rear axle and brakes, and fix the emissions equipment, and I should be set for a while
  18. #143
    Jul 2015
    Dallas, Texas
    98 750iL, 01 740iL
    the car is lowered in the front?
  19. #144
    Aug 2015
    Quote Originally Posted by MKIVJZA80 View Post
    Coilovers in front, rears will go in with the new axle. I suppose you could say it's lowered in the rear as well, if you count leaking, bottomed out SLS lowered. I can't stand rake though, the rear needs to be low.
  20. #145
    Jan 2015
    Tempe, AZ
    1995 525i/5
    I seriously think this 750il is the nicest car you've owned so far. Decent engine, what appears to be good paint, and has a fairly straight body.
    1995 525i 5-speed - Thread
  21. #146
    Aug 2015
    Quote Originally Posted by dannyzabolotny View Post
    My E39 was without a doubt the cleanest car I had, I got that for a steal. Paint was beautiful, a total of two dings over the car. It was pampered the first 180k of its life, being a dealer car for about the first 60k. It was high mileage, but everything on it was in near perfect condition and very well maintained.
    The body of the 750il isnt as good as it looks in pictures, paint is badly scratched over the entire vehicle, bumper is cracked in many places, the interior is very worn out, bad rust on two doors. However, I plan on making this $700 car into a $7000 car over the next several years.
  22. #147
    Jan 2015
    Tempe, AZ
    1995 525i/5
    You'd be surprised what a good paint correction could do. It may not make the paint perfect, but it'll probably make it a lot better.
    And I'm excited to see what you'll do with this car long term.... as long as you don't crash it.
  23. #148
    Aug 2015
    Playing catch-up a little bit, here's the work from last night, this hose from my O2 pump had pretty much dissolved
    IMG_20170730_011414 by Colton Hatcher, on Flickr
    I found this, which would explain my my slightly rough idle.
    IMG_20170730_010913 by Colton Hatcher, on Flickr
    On to today, I got the 740il's subframe dropped-ish. I need to chop up the exhuast some more to get it out from under the car, but everything is disconnected.
    IMG_20170730_230659 by Colton Hatcher, on Flickr
  24. #149
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Holy rust, batman. Good find on that intake boot, that'll definitely mess up your idle. That's the M73's achilles heel in my opinion— vacuum leaks. There are so many little hoses everywhere and everything is doubled so it's a lot of fun to track it all down.
  25. #150
    Aug 2015
    There's a lot of bad rubber on this car, not looking forward to replacing all of it :/
  1. Dual fuel injection w/ only 1 injector driver per cylinder
    By M3 Muscle in forum Forced Induction
    Last Post: 06-28-2009, 09:44 PM
  2. Per-cylinder injection control
    By sniper in forum Forced Induction
    Last Post: 03-30-2008, 11:08 PM
  3. Ideal Compression per Cylinder
    By caseypons in forum 1982 - 1988 (E28)
    Last Post: 03-13-2007, 01:37 AM
  4. valves per cylinder
    By Driftin E46 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-17-2005, 10:48 AM
  5. 318 heads, how many valves per cylinder
    By ////MPower in forum 1983 - 1991 (E30)
    Last Post: 03-18-2005, 01:46 PM
