Page 4 of 9 FirstFirst 123456789 LastLast
Results 76 to 100 of 221
Thread: Colton's $38 per Cylinder Restoration: A Probable Financial Disaster
  1. #76
    Aug 2013
    AZ
    1998 BMW 750iL
    Quote Originally Posted by ColtonBH View Post
    Main things to fix right now are rear suspension, distributor seals, and tires
    Tires, I have a few options, none of them are good.
    I have a set of 15s with good tires, which obviously don't fit
    I have the 16s that came with the car, but all mismatched tires
    I have the 16s from my 740il, but they are badly flat spotted from my accident
    I have 18s with bad tires, and 74.1 center
    I have 18s that I need to finish refinishing, and I have a set of good tires for those
    I have a couple assorted 16s from my e39
    So out of all that, I don't have a single good set of wheels and tires at the moment :/
    I'm running the flat spotted tires right now, which is fine because my I don't go over 50 going to work, but over 60 they are a nightmare. Considering buying snow tires while they are fairly cheap and running those until my 18s are done, at least they will be round
    Sent from my Nexus 6P using Tapatalk
    Sell the wheels and tires that you do not use and buy a set of tires off Craigslist to fit the wheels you want to keep
  2. #77
    Aug 2015
    Oconomowoc, Wisconsin
    01 750il, E38/9 Parts
    Still having battery troubles, replaced the top battery with the one out of my 740il. Now it will not start with that one in, I'm running just on the bottom battery right now. Im hoping it's just a charge issue, it's been sitting in the car for a month or two now without being started, so I have it on the 20a charger at work (my home charger is a wimpy 2a), so hopefully that gets it charged enough where I can start up with both batteries installed
    --- 750il Maintenance/Restoration Thread --- E38/9 Parts Cars --- YouTube Channel ---
  3. #78
    Aug 2015
    Is there a DIY on doing the distributor seals?
  4. #79
    Aug 2015
    Loads of used basket weave wheels around $200/set. Cheaper than buying a new set of tires, and when the tires are spent, I can scrap the wheels, or sell them for $100 or so
  5. #80
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    If you keep going this route your 750 will end up parked on your lawn without any chance of being back on the road
    Instagram.com/nordmanmg
    Your current situation is not your final destination
  6. #81
    Aug 2015
    Quote Originally Posted by NordmanMg View Post
    I have a set of good wheels and tires, but the wheels need to be refinished before I mount tires. I need something temporarily that I can turn around and sell when I'm done. The only tires I have now that fit the e38 right now are flat spotted, and rather than buy brand new tires for a set of 16s that I'm not gonna put that many miles on, I'd rather get some for cheap that aren't flat spotted, and spend that money on getting the rest of the car in better shape.
  7. #82
    Sep 2014
    '01 DINAN7 '03 M5
    You have few nice sets for sale in your local cl
    $600 with looks to be nice tires,
    https://milwaukee.craigslist.org/wto/6179981640.html
    $450 for the set of looks to be very clean wheels with tires you can use for a season
    https://chicago.craigslist.org/chc/wto/6193294537.html
    if this would pop in Denver they would be in my garage already !
    factory M5/6 fully forged wheels with nearly new Michelins? Oh boy
    https://chicago.craigslist.org/chc/wto/6196299103.html
  8. #83
    Aug 2015
    Might spring for that top set, I missed that one. I'll throw a couple sets of wheels I don't need or that don't fit up for sale, and see where we go from there
  9. #84
    Aug 2015
    Okay, attempting to figure out the squeal now.
    First off, my year old, off brand battery doesn't seem to be doing a good job of holding a charge, so I put my several year old genuine BMW battery in, right now its on real low charge, so that seems to be the reasons for my low voltages.
    There is an incredibly loud squealing/chirping sound coming from the front of the car. Originally, it seemed too correlate for the most part with engine temp, going away when fully warmed up. Now with the lower charge battery, it would not go away for more than a short time, even with the car fully warmed up. I had voltage up on the dash, and I noticed, whenever the voltage when under 13v, the car started squeaking, above 13.5v, the car did not squeak.
    I realize correlation does not equal causation, but should I be thinking alternator? I should mention, this is with HVAC entirely off, so no AC kicking in, I can't come up with anything else that would affect both the serpentine belt and voltage, but if anyone has ideas, it would be a great help.
  10. #85
    Jan 2017
    North Carolina coast
    2001 740iL Prod 4/2000
    sounds like serpentine belt from alternator load. Check all the pulleys and belt for dirt/grime packed in the grooves, condition of the pulleys themselves.
    If the belt looks questionable replace it.
  11. #86
    Oct 2003
    Seattle
    99 M3
    Could also be a lazy or weak or seized belt tensioner that cannot re-tension the belt right after startup.
  12. #87
    Aug 2015
    Okay, cool. I will probably just buy both belts and tensioners, then I won't have to worry about it, I don't want to have to pull the whole front end apart more than once
  13. #88
    Jul 2016
    2004 R32, 2011 A4 Avant
    Might want to think about the alternator too while your in there. A healthy one shouldn't be putting out anything below about 13.5, even under full load.
  14. #89
    Aug 2015
    Quote Originally Posted by KSEADUB View Post
    It's weird, the voltage will be anywhere from 9.0 to 13.8, its such large swings.
    Anyway, I lost half a belt on the drive home from work, so I can't do anything until I get parts in the mail
  15. #90
    Sep 2014
    '01 DINAN7 '03 M5
    Maybe sometimes, before you got the car, the alternator been replaced with a V8 one?
    You have to measure alternators pulley, V8 have larger pulley, V12 have smaller one due to lower idle rpm range
    if so, it will not gonna charge or give enough power to keep battery alive
  16. #91
    Jul 2016
    Chicago, Illinois
    are slow
    Both pulleys work, in practice it doesn't really make a difference.
  17. #92
    Sep 2014
    '01 DINAN7 '03 M5
    Quote Originally Posted by XAlt View Post
    V12 with V8 pulley discharging battery on idle rpms
  18. #93
    Aug 2015
    Driver side hood latch isn't opening :/
    This car really isn't playing nice with me
    Anyway, I ordered a used alternator, I'm guessing that was the cause of my problems, considering my alternator belt shredded, and the weird voltage crap. If the one on the car currently is just a bearing issue, I'll put in new bearings and keep it as a spare. Anyway, with both belts and tensioners, as well as an alternator in the mail, I'd like to think all my issues will be solved.
    Since the car is out of commission for a few days, I'll start getting rear end parts pulled off of my 740il to go in this car, I'll get the rear coilovers in, sls deleted, and with any luck, I'll be good for a little while.
    I should note that I'm getting a P0740 code, torque converter lock up something or other, which is fortunately the only code the car is throwing. Since I don't drive highway that much anymore, I'm not going to worry about it for a while. It hasn't affected anything that I can feel with the car.
  19. #94
    Aug 2015
    Also, if anyone in the southern Wisconsin/northern Illinois area wants to do a facelift conversion on an orient blue e38, hit me up. I like the pre facelift front end better personally
  20. #95
    NYC
    99 IL/13 SXT/04 Audi A4
    Quote Originally Posted by xboss View Post
    I have some wood tissue holders coming out, I promised Nord one of the first since he sent me a wood part.
    WELL i AM ALSO WAITING BUDDY
    El Cid 1999 IL
    DUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
  21. #96
    Aug 2015
    2.81 rear in 750il, 2.93 in 740il, right?
  22. #97
    Aug 2015
    Got new tensioners and belts in, so now I just have to wait on the alternator, and I get her up and running again. Until I get into the rear suspension, then we'll be back into it.
  23. #98
    Aug 2015
    Here is my first interior mod for the car. This is a piece of e39 trim that I had lying around, so before I destroy my e38 trim, I would test it out. Boy is that finish tough, it took me many coats of aircraft stripper to get that far, I might have to try out a few more strippers just to keep my sanity. There is a little bit of the finish left on, but some stripper on that should get rid of it easy, and then I will do one more coat all over in order to pull as much of the original color out as possible. I also need to figure out a finish to go over, I would like to do a one part, since doing many coats of a 2 part would be a huge pita. I'm planning on spar urethane, and maybe baking it for a few hours to see if i can get it reasonably hard.
    IMG_20170708_192619 by Colton Hatcher, on Flickr
    IMG_20170708_192615 by Colton Hatcher, on Flickr
    I should note as well, the cracks that were in the original finish seem to go all the way through the wood, so there will be a couple lines coming through when it's finished, however, since it will be black, I don't think it'll be noticeable to be worth finding a full set of uncracked trim to strip and refinish. I am also very happy that the stripper isn't pulling whatever glue or epoxy is used to hold the veneer to the backing.
  24. #99
    Aug 2015
    Seems as though my cable has either come unhooked from the latch itself, I can't get it to open by the usual methods. Next step, I'm going to try to break the hood latch with a crowbar or something, I just really hope I don't have to cut open the hood.
  25. #100
    Sep 2014
    '01 DINAN7 '03 M5
    You can try to cut hood hooks , remove kidney grills off and you might be able to cut with saw blade
  1. Dual fuel injection w/ only 1 injector driver per cylinder
    By M3 Muscle in forum Forced Induction
    Last Post: 06-28-2009, 09:44 PM
  2. Per-cylinder injection control
    By sniper in forum Forced Induction
    Last Post: 03-30-2008, 11:08 PM
  3. Ideal Compression per Cylinder
    By caseypons in forum 1982 - 1988 (E28)
    Last Post: 03-13-2007, 01:37 AM
  4. valves per cylinder
    By Driftin E46 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-17-2005, 10:48 AM
  5. 318 heads, how many valves per cylinder
    By ////MPower in forum 1983 - 1991 (E30)
    Last Post: 03-18-2005, 01:46 PM
