So I am about 80% done with my e38 rehabilitation (but I truly fear the last 20%) and my speakers stop working. I know it is not the radio, as the monitor still works and I can see the station showing up on it, but I am trying to find where things could be going wrong. My mechanic's guess is that it is somewhere directly behind the radio 'in the wires somewhere' but I am wondering if there might be another answer. I'm not sure what makes sense here: Amplifier? Other wire/solder breaking down? Any direction would be helpful!
amp.
Fuse or the whole thing? (by the way, thanks for the quick reply - I was going to have a peek in the morning)
Replace the amp with one just like it.
[/IMG]
Crap, I was hoping it was just the fuse.
Yeah, you'd hope it was just a fuse (maybe) - check the one back by the battery. But Mool's likely right that the amp went south. Mool; might it be the NAV also? I had issues with my setup and it was the NAV.
Got a junk yard nearby? May not be ideal, but, I've had a lot of good luck on stuff like this at our local bone yard. Basically just plug 'n play (just disconnect battery first).
'01 325Ci Convertible, 5-speed
'01 740iL, Stahlblau with beige interior & 18" M-Pars, GROM bluetooth
'03 X5 3.0 six cyl, Gray on gray
Just tried it; NAV working fine.
But in light of the posts above, I don't feel better...
Is the relevant fuse listed by name?
whats the other 20% of the rehabilitation? aside from your amp?
The 20% is 80% suspension. Weird clunky noises on some bumps, occasional snapping noises in the front when steering hard over, possible edc/sls failure (edc is always on, very firm, rear of car a little saggy), adjustment of sunroof necessary, cigarette lighter needs to be reconnected. Air bubble in cooling system that can annoy.[=ericwudi0830;29750163]whats the other 20% of the rehabilitation? aside from your amp?
But I'll tell you, nothing limps like a BMW. With all the issues it has remaining, it is still gossamer at 80mph. And since I had the flex disk replaced, it is magnificent in terms of acceleration. This was my flex disk...
'nuf said. I unwittingly drove from Ontario to TN to VA (3000km) with it like this. Only a BMW...
---- Processing Individual ----
Z1XX Upholstery
Seats front and back in Epingle / leather englishgruen,
As Schl.Nr. B9EG.
Front seat backrest in Montana Englishgruen (No. 8 174 861)
Other interior equipment as for Volleder Nappa englischgruen,
Schl.Nr. P5EG
My 99 Rear deck speakers don't work? Every other speaker works. Is that an amp problem? or a connection issue?
