the gps decimal degrees is 5, needs to be 6 to use with circuit tools vbo export, you can see the erroneous data here.. GEMS does not have this problem but none of my friends run data that can import into gems so it's not terribly useful to me. I use harry's to log and export the data in vbo format, it's very handy when I have time to get on the pc and really dig into the laps
http://forum.gps-laptimer.de/viewtopic.php?f=9&t=4356
I do not like racerender, I did not think it supported the mk2 so no live anything I do not bring a laptop to the track to overlay between sessions, harry's can do this so I can at least see live and change/improve. half my buddies run racerender because odb2 works for them, and racerender exports to VBO too so I can compare data with them.
the biggest problem with harry's right now is the racecapture devices do not support direction, they even have a compass but they never enabled it or a calculated direction. This causes big problems when you autocross, the start/stops NEVER work for me, you have to run full manual and it's a pain, the laptimes are always wrong because the triggers fail. When I sit in grid you can watch the map spin like a top because the app does not know what direction you are going
harry's should have a fix for this racecapture issue, calculating direction off the gps data. Hopefully it's soon as the autocross season is almost half over, 2 events this weekend and I'm still manually recording and really dont know how fast my runs are due to the trigger issue
