Results 1 to 5 of 5
Thread: rust bubble - need advice
    Ithaca, NY
    528iT
    Hi All,
    I was washing my car and noticed what appears to be a rust bubble (see arrow pointing to it in the pic). Any chance this would be covered by BMW warranty? If not, should I use a rotary tool to get rid of the rust, fill in w/bondo and paint?
    Thanks in advance,
    RM
    Feb 2017
    Metairie, LA
    2001 325i; 2006 325i
    Those look like they rusted from the inside out. My guess would be that you are way beyond using a rotary tool. Is your car under the factory warranty? I have to ask because I have no idea how long a factory warranty lasts.
    Not going to be covered under warranty.
    Sep 2008
    Orlando, FL
    02 M3
    probably cheaper and easiest to buy a used trunk if you can find it.
    Apr 2017
    Neosho, MO, USA
    95 Mercedes C220
    First I'd suggest looking inside the trunk to see if there is signs of rust on the inside. If not, its a lot of work to paint the lid for that small of a spot. I don't know if you can still buy them, but they actually make a small sanding pen with a small tip with abrasive on it. I would sand the small bubble off then get some touch up paint to go over it so it doesn't keep rusting. In fact if you got base color and some clear, you could then build the spot up, then block it flat with some 2000 grit, a little polishing and you will never know its there. This will only work if you can keep the repair area very small. If the rust spot is bigger underneath than what your picture shows, then you may be better off to paint it.
  1. New to painting, need advice on rust
    By copracr in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 08-29-2011, 12:13 PM
  2. Need advice on exorcising the rust demon from my car!
    By Johnny Ausome in forum 1991 - 1999 (E36)
    Last Post: 11-07-2010, 08:48 AM
  3. Rust Pics! Need advice
    By Funez in forum 1991 - 1999 (E36)
    Last Post: 08-31-2007, 05:50 PM
  4. Need rust removal: Welding advice needed.
    By Andy in forum Middle Atlantic - US
    Last Post: 02-10-2006, 01:20 PM
  5. Rust spots need your advice
    By keke1985 in forum 1991 - 1999 (E36)
    Last Post: 03-21-2005, 03:53 PM
