Results 1 to 7 of 7
Thread: Front brakes locked up @ autox (no abs), driver or hardware failure?
    Aug 2016
    Louisville
    1996 M3 Coupe
    This weekend was my first autocross on new rotors and pads.
    Pads in the front are Hawk Street/Race and I added slotted rotors. Rears are running standard Axxis and blanks. Fresh ATE200. Front brakes are sparklers
    Needless to say the brakes got quite a workout on their first session (maybe more-so than they should, I also have a codriver). Abs worked fine until the last session.
    On the last run when I jammed on the brakes, both times I encountered complete wheel lock with no abs. abs never threw a light. Car drove fine on the way home, braking seemed decent, I had a full car load so I did not try to test them hard.
    Am I just running too aggressive up front and needing to change the back brakes as well? The only thing I can say is beforehand I mentioned to my driver that the pedal seemed a bit soft.
    Any thoughts?
    Marietta, GA
    95 M3, 87 535is
    Had a similar problem last year, ended up being a faulty wheel speed sensor. Front passenger side if I remember correctly.
    Aug 2016
    Louisville
    1996 M3 Coupe
    Literally 3 weeks back I ran through the entire ABS diagnostic guide from bavauto. Everything checked out in range, including the values for the wheel speed sensors (as measured from the abs module in the dash).
    Did your issue sensor throw a fault or anything?
    Marietta, GA
    95 M3, 87 535is
    I don't recall exactly but I think the ABS light came on when my wheels locked up during autocross.
    All my sensors checked out fine when doing the static resistance test but I tested them individually at each wheel and the signal wasn't being generated when the wheel was spun for the front right wheel.
    Aug 2016
    Louisville
    1996 M3 Coupe
    Thanks for the reply. Ill test the fronts at the plugs and see if they read ok. I guess I should clean them and the trigger wheels too to take it out of the equation.
    Aug 2002
    Auburn, GA
    1997 328is and 1998 328i
    Did they lock for an entire run? Could you turn the car off and on and reset everything? Often time, when they come across an uneven path of asphalt, the sensor will freak out enough where it'll turn off (assuming theer's a mechanical issue).
    WUTCONE?
    Oct 2003
    Seattle
    99 M3
    Seems like brake bias may be an issue, can you engage the ABS now?
  1. Driver side front brake locked up
    By Mach1driver73 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-13-2013, 05:41 PM
  2. Front Brakes Lock Up
    By dnkomos1 in forum 1995 - 2001 (E38)
    Last Post: 03-29-2012, 07:15 AM
  3. Front brakes locked up on me
    By waffle808 in forum 1995 - 2001 (E38)
    Last Post: 07-08-2011, 03:03 AM
  4. Help 97 Z3- Front Brakes Locked up
    By ruprectgern in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-24-2009, 01:44 PM
  5. e39 Front brakes locked up after doing brake job
    By Mike981212 in forum 1996 - 2003 (E39)
    Last Post: 07-28-2009, 02:10 PM
