Results 1 to 8 of 8
Thread: Brake question
    Jan 2017
    Ontario, Canda
    1991 BMW e34 525i
    Brake question
    I've scoured the search and Google but can't seem to find a definitive answer:
    Will e46 calipers and rotors fit on an e34?
    I know that e36 m3 calipers are the same as 3.6 M5 calipers. I know the rotors have the same diameter and thickness but it seems the only difference is the hat offset.
    E46 330i brakes and calipers are a direct bolt on upgrade for e36s, therefore shouldn't the bolt patterns be the same for the e34?
    Could you make up the hat offset difference with spacers?
    Has anyone tried this?
    Looking for budget friendly alternatives to upgrade my 525i's brakes. 540i brakes are a step up and easy to find. 3.6 M5 single pot brakes are easy to find too (due to the calipers being the same as the e36 m3) but rotors are harder to source. The 3.8 M5 and 850csi 2 pot brakes would be great but not worth the price imo.
    330i brakes would be stupid easy to source and theoretically offer better braking than the single pot M5 brakes.
    Anyone have any inputs on this? Anyone tried it?
    Sent from my SM-G930W8 using Tapatalk
    Nov 2009
    Realville
    93 525iT,91 318i
    Did you try the brake interchange chart?
    http://www.bmwe34.net/E34main/Upgrade/Brakes.htm
    Jan 2017
    Ontario, Canda
    1991 BMW e34 525i
    Quote Originally Posted by locknload View Post
    Yea but it has no mention of e36/46 brakes.
    The e36 m3 brake calipers have the same part# as the e34 M5 3.6 brake calipers, and take the same dimension rotor.
    It's a good guide but could use an update.
    Oldham UK
    '00 330i Sprt '92 525i
    Think you might struggle to make the 330i parts fit. The rotor is 325 x 25. IIRC, the 525i ones are 302x22. The M3/M5 appear to be 'only' 315 x28 Would E34 wheels even fit over them? I have staggered 18" wheels on my 330i and a spare set in the shed if you need any measurements.
    PS The 330i has brake ducts. Not sure you would need them on the 525i but I don't imagine they were fitted for show
    Jan 2017
    Ontario, Canda
    1991 BMW e34 525i
    Quote Originally Posted by whiskychaser View Post
    According to e36 sources you'll need an absolute minimum of 17" to fit the 330 rotor and brake setup. But since the e34 comes stock with fairly low offset 17s I gotta think it wouldn't be as much of an issue...
    I guess I'll have to bite the bullet and experiment with junkyard parts.
    Maybe someone with more engineering knowledge can explain why the different hat offsets on the rotors will seriously affect the fitment...
    May 2005
    OH
    Quote Originally Posted by Philth View Post
    E36 M3 use spindles that allow interchange of the E34 carriers.
    Regular E36 use different parts that allow interchange with most E46 brake options. Hence you cannot take E46 brakes and install them on E36 M3 without a lot of work.
    Breaking now...
    E65/E66: '04 760Li, '08 750Li
    E60: '08 535xi, '08 528xi, '07 530xi
    E53: '02 4.4i, '05 4.4i, '03 3.0i
    E46: '01 330ci
    E39: '97 528i, '01 530i x3
    E38: '01 740iL
    E36: '98 328i
    E34: '92 525i
    ...and various others > more pics & info
    >> Like my facebook page - facebook.com/bimmerpc
    Jan 2017
    Ontario, Canda
    1991 BMW e34 525i
    Quote Originally Posted by kalevera View Post
    The answer I was looking for! Thanks
    Sep 2014
    Oregon, USA
    1989 535i
    The brake chart is generally very good. But.. its missing some data. For instance E60 m5 calipers will bolt on in the front with larger rotors. The e60 m5 calipers do require an 18 in rim though.
    1991 E34 535i Artic Gray
  1. brakes question
    By 00soul in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-20-2001, 05:26 PM
  2. New Brakes Question
    By ///M3Dave in forum 1992 - 1999 M3 (E36)
    Last Post: 07-09-2001, 02:29 AM
  3. Odd Braking Question...
    By Kevlar in forum 1992 - 1999 M3 (E36)
    Last Post: 05-26-2001, 03:13 PM
  4. Brake question
    By jayhudson in forum 1992 - 1999 M3 (E36)
    Last Post: 05-16-2001, 10:34 AM
  5. brake question
    By jon in forum 1991 - 1999 (E36)
    Last Post: 05-08-2001, 12:29 AM
