Hello gentelmen, I won to now if is posible install two gauges VDO (oil press and voltimeter) in the console of my Z3 no M roadster without change the console.Thanks a lot.
If you don't want to change the console, where would you put the gauges?
Easier to add them on the A-pillar
http://www.wpsracing.com/aumepigapobm5.html
BMW MOA 696, BMW CCA 1405
I think you're able to put them in place of the A/C vents, I would grab a workshop manual for the wiring diagrams.
888.280.7799 | 6am - 5pm PST
I'm not sure how you would do it without removing the console. This is what I did on my 2.5i. It required using a second upper panel and some custom cutting and fabrication. Then the console had to be removed to install the panel.
O.K. is more or less that I won. Thank
you
Other than finding a place to fit the gauges, how challenging is it to tap into oil pressure/temperature? I have an M52 if it matters.
Rally Road has another option...you can run two gauges behind the steering wheel. I've had mine in a box for 18 months or so, but I'll get to it someday. Life got in the way a bit
https://www.bimmerforums.com/forum/s...Road-Gauge-Pod
Nathan in Denver
I was thinking about this this morning and realized I all I ever use for audio is bluetooth. There are many hidden audio systems you can get, or cobble one together. Where the radio is is perfect for gauges:
http://www.glowshiftdirect.com/unive...1i0xoCtGLw_wcB
