Not sure how well this unit works with BMW but it is on sale for about half price. I think I'm not suppose to post a link... it's at Amazon
- Important: It is customized version of MD802, which needs to select and download vehicle software by yourself before using. You can Free Get One Vehicle Make Software as Your Choice at the first time and purchase other vehicle software by paying USD10 for each vehicle.
- Autel’s Breakthrough Diagnostics Tool capable of accessing every module within each vehicle system, it is the combination of All Systems Access (Engine, Transmission, ABS, SRS…and more), OBDII Scanner, Oil Rest and EPB for the vehicle brand of the Users Choice.
- Auto Scan all available modules to check the status, which only needs a few minutes to finish the full scanning.
- Reads and clears all systems (EPB/SBC, ABS, SRS, Engine…) trouble codes; Turns off the ECU and brake warning light; Set brake pad thickness and Open/Closing Brake Calipers; Oil/Inspection/Service light Reset; View Live data Graphing and Freeze Frame.
- Brand New Updating System: No need Card Reader, update/download software via USB cable. Auto-Read Serial No. and Register Code; Compatible with Windows PC only.
Autel Code Reader Diaglink (DIY Version of MD802) All Systems/Modules Diagnostic for ABS, SRS, Engine, Transmission etc, EPB, Oil.
$85.99
