Page 3 of 6 FirstFirst 123456 LastLast
Results 51 to 75 of 143
Thread: Rebuild: Better, Faster, Poorer - Twin Screw Edition
  1. #51
    Apr 2013
    Alabama
    1995 M3 Coupe
    Quote Originally Posted by vollosso View Post
    Fuzzy pictures. But i think det marks on the piston and head.
    No pitting on the piston, pic of the head
  2. #52
    Apr 2013
    Alabama
    1995 M3 Coupe
    Clean Pistons
  3. #53
    Apr 2013
    Alabama
    1995 M3 Coupe
    So i might have fucked up yet again. Removing dowels from the block with some pliers...the pliers slipped and gouged the block right where one of the cut rings is supposed to go. It catches with a fingernail...not sure if it's anything I can fix or not. Kinda sick to my stomach about it. Didn't get a picture of it yesterday I'll get one home tomorrow. Thinking about carrying the block to the machine shop and just having them deck and reassemble the bottom end.
    1995 M3...Screwed
  4. #54
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Man you got this thing torn this far apart you'd be crazy not to refresh the bottom end too. I thought that was the plan all along. I'd at least get it decked, honed, and tanked and then throw new bearings and rings in.
  5. #55
    Apr 2013
    Alabama
    1995 M3 Coupe
    Wasn't planning on it, bottom end was in good shape.
    Here's some pics of my dumbassedness
    I would love to have you guys tell me to stop being a sissy and sand it and roll with it...
  6. #56
    Feb 2012
    1995 BMW M3
    Stop being a sissy and pull it apart and refresh it. Got 200k on it.
  7. #57
    Apr 2013
    Alabama
    1995 M3 Coupe
    Quote Originally Posted by rajicase View Post
    It's got another 200k to go
  8. #58
    Manchester, N.H.
    96 332IS 6466 turbo
    Run it.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  9. #59
    SOCAL
    IG: Clearsandadrop
    This is good advice, just having the peace of mind that you built it right is worth it.
  10. #60
    Tanks95's Avatar
    Tanks95 is offline M3s Only Have Two Doors BMW CCA Member
    Nov 2002
    North Carolina
    I6 & V8 ///M
    Refresh it man, its the best option.
    If your M3 doesn’t have 3 pedals and 2 doors, I would really consider contacting BMW to confirm the authenticity of your incorrectly badged mid-sized family sedan.
  11. #61
    Manchester, N.H.
    96 332IS 6466 turbo
    Bottom end rebuild will keep the car off the road for probably another extra 1-2 months. Plus $2k +. I'd run it.
    1996 332IS
    Built 3.2
  12. #62
    Feb 2012
    1995 BMW M3
    I can definitely see another 4-6 weeks, but cost should be nothing near that. I did my fully built forged bottom end for less than $2k.
    Rings: $150
    Main bearings: $80
    Rod bearings: $40
    Machine work: $200
    Gaskets/seals/etc: $100-150
    Hardware: $100-200
    If he hadn't pulled the motor out of the car and completely stripped it down, and it didn't have 200k on it , maybe it would make sense to just stuff it back in the car.
  13. #63
    Apr 2013
    Alabama
    1995 M3 Coupe
    Did get a giant package yesterday:
    Replaced all of the hose barbs, replaced all seals and bearings, and put two Kenne bell stickers on...lame imo (terrible picture)
    Thinking on the full on rebuild, also thinking about running it. Budget....whats that?
    1995 M3...Screwed
  14. #64
    Apr 2013
    Alabama
    1995 M3 Coupe
    Double check me here, this is everything I think I need if I rebuild the bottom end (Including Part Numbers):
    Went with VAC bearings. Buying new chains as well. Im assuming the bottom end gasket set has everything in it.
    Bottom End Gasket Set - 11119064460
    Rod Bearings - VAC VAC-HPRBS-M50
    Main Bearings - VAC VAC-HPMBS-M50
    Timing Chains - VAC BMW-TC-M52
    Piston Rings - 11251403810
    Rod Bolts - ARP 201-6201
    I've never plastigaged anything before, no idea how to gap rings or install them. Reuse pistons and rods? Ugh...this is exhausting.
    1995 M3...Screwed
  15. #65
    Feb 2012
    1995 BMW M3
    Hey man I've got mint rod bolts I'll let go cheap. They are ARP!
    I also have a ring file you can use. And plastigsuge.
    Also I can show you how to gap rings and install them.
  16. #66
    Tanks95's Avatar
    Nov 2002
    North Carolina
    I6 & V8 ///M
    Quote Originally Posted by Jab31169 View Post
    A budget is just some fictitious meaningless number we place in our head to make us feel comfortable about spending excessive amounts of money on 20 year old cars.
  17. #67
    Apr 2013
    Alabama
    1995 M3 Coupe
    Quote Originally Posted by Tanks95 View Post
    Yea, that sounds about right
    1995 M3...Screwed
  18. #68
    Apr 2013
    Alabama
    1995 M3 Coupe
    Dropped the head off today, supposed to be done by next Thursday. He was of the opinion that he didn't want to deck the block for the scratch, Non-committal on the rebuild of the bottom end, which is where im at with it.
    1995 M3...Screwed
  19. #69
    Apr 2013
    Alabama
    1995 M3 Coupe
    So when I bought this car, it was advertised as having a Stewart water pump:
    New Behr Radiator
    New Stewart Water pump with Metal Impeller
    New 80-Degree Thermostat
    New Thermostat Housing and Seal
    When I pulled the water pump the other day I thought to myself "this doesn't look like a Stewart"
    So turns out its a Graf, a $40 dollar water pump.
    Bimmerworld happend to have a sale on Stewart pump on sale the other day so I picked one up
    Not gonna lie, kinda pissed about that. The guy I bought it from only drove it twice so he didnt know and Im not real sure if the person who had the car before him knew or not as I dont know if a shop put it in for him or not. Pretty shady stuff.
    1995 M3...Screwed
  20. #70
    Mar 2012
    Renton, Wa
    98 m3
    Probably told the purchaser before you it had a metal impeller pump and that guy thought that meant Stewart.
    1989 535i - sold
    1999 Tiag/Dove M3 - sold
    1998 Turbo Arctic/black - current
    2004 TiAg/Black - Current
    PTE6870 | 1.15 ar | Hp Cover, Custom Divided T4 bottom-mount, 3.5" SS exhaust, Dual Turbosmart Compgates, Turbosmart Raceport BOV, 3.5" Treadstone Intercooler, 3.5" Vibrant resonator and muffler, Arp 2k Headstuds | Arp 2k Main studs | 87mm Je pistons | Eagle rods | 9.2:1 static compression, Ces 87mm cutring, Custom solid rear subframe bushings, Akg 85d diff bushings, 4 clutch 3.15 diff, , Poly engine mounts, UUC trans mounts W/ enforcers, 22RPD OBD2 Stock ECU id1700 E85 tune, 22RPD Big power Transmission swap w/ GS6-53
  21. #71
    Apr 2013
    Alabama
    1995 M3 Coupe
    The ad was a direct copy of the original owner's ad. Again, even he might not have known and got duped by a shady shop.
    1995 M3...Screwed
  22. #72
    Apr 2013
    Alabama
    1995 M3 Coupe
    Haven't gotten a lot done in the last week or so. I've been busy with life and getting ready for 24 hours of Chump Car at VIR. Got the radiator back with the new oil cooler that fits yesterday.
    1995 M3...Screwed
  23. #73
    Apr 2013
    Alabama
    1995 M3 Coupe
    Head was supposed to be done yesterday, just spoke with the shop owner and they have yet to even look at it. When I dropped it off, the shop owner was out of town so I kinda had a bad feeling dealing with one of the techs and the way he wasn't really writing anything down besides my name. Anyways, they are throwing it in the tank today and pressure/vac testing it on Monday. I'll be out of town middle of next week so I wont have the head back til the 16th or 17th. Im thinking I wont have this car done before the fall HPDE at Barbers....gotta find a car to rent.
    1995 M3...Screwed
  24. #74
    Feb 2012
    1995 BMW M3
    Cylinder head services in fairfield?
  25. #75
    Apr 2013
    Alabama
    1995 M3 Coupe
    Couldn't get them on the phone or even a call back. Called a few local shops and asked who they used for head rebuilds and ended up taking it to Engine Rebuilders in trussville.
    1995 M3...Screwed
  1. REBUILD: Done with the Twin Screw, Going TURBO!
    By Tanks95 in forum Forced Induction
    Last Post: 11-30-2016, 12:44 AM
  2. Post-Rebuild Twin Screw Dyno
    By Neil in forum Forced Induction
    Last Post: 02-23-2009, 04:26 AM
  3. Post-Rebuild Twin Screw Dyno
    By Neil in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-18-2009, 10:05 PM
  4. Stimpee's twin-screw
    Last Post: 06-13-2003, 03:58 PM
  5. Whipple twin-screw.... ???
    By NoSoup4U in forum Forced Induction
    Last Post: 05-17-2003, 12:51 PM
