Page 2 of 6 FirstFirst 123456 LastLast
Results 26 to 50 of 143
Thread: Rebuild: Better, Faster, Poorer - Twin Screw Edition
  1. #26
    Dec 2002
    Broward, FL
    I take the bus to work.
    looking forward to seeing the final product.
    -M3J0N
  2. #27
    Apr 2013
    Alabama
    1995 M3 Coupe
    Quote Originally Posted by m3j0n View Post
    Ment to email you a link the other day to this thread, thought you might get a kick out of it. Mackin texted me the other day about the car and I gave him the news.
    1995 M3...Screwed
  3. #28
    Apr 2013
    Alabama
    1995 M3 Coupe
    Got some more done tonight, motor and trans are fully ready to come out, just have to hook up the hoist and unbolt the motor mounts. Might get that done tomorrow or sunday, got some family obligations to attend. Anyways lets get to the pics.
    The middle of the 3" exhaust I had fabbed up
    Those welds doe
    Shifter out
    Fuck this clip in particular
    I like to recycle things because global warming
    So glad I pulled that stupid ass tunnel blanket the last time the trans was out
    My pimp ass LED sylde flashlight with a magnetic base
    1995 M3...Screwed
  4. #29
    Apr 2013
    Alabama
    1995 M3 Coupe
    It's out:
    Headers had a leak me thinks...idiot installer...wait that was me
  5. #30
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Smdh should get a refund for that kind of sloppy work...
  6. #31
    Apr 2013
    Alabama
    1995 M3 Coupe
    Quote Originally Posted by rajicase View Post
    Guys an asshole, he won't care
  7. #32
    Apr 2013
    Alabama
    1995 M3 Coupe
    Got a bit more pulled off tonight
    Fancy coil packs
    Always wondered where my vdo water temp sensor was
    Stock intake cam and schrick exhaust cam
  8. #33
    Feb 2012
    1995 BMW M3
    Aside from replacing the HG, what else are you doing that warranted pulling the motor?
  9. #34
    Apr 2013
    Alabama
    1995 M3 Coupe
    Get a lay of the land really. I knew the headers were going to be a bitch to get off with the motor still in the car. As you saw, I couldn't even really tighten them up that well on the car. Replacing some aging coolant hoses, cleaning up the bay a bit. Also looking for a new transmission...would like to do a 6spd but I don't know if its in the budget. Getting real tired of the 1-2 50/50 grind.
    1995 M3...Screwed
  10. #35
    Apr 2013
    Alabama
    1995 M3 Coupe
    Let it ride or replace the flywheel surface for $90 bucks? Using a ceramic clutch that still has life left in it.
    1995 M3...Screwed
  11. #36
    Tanks95's Avatar
    Tanks95 is offline M3s Only Have Two Doors BMW CCA Member
    Nov 2002
    North Carolina
    I6 & V8 ///M
    good stuff, im in!
    If your M3 doesn’t have 3 pedals and 2 doors, I would really consider contacting BMW to confirm the authenticity of your incorrectly badged mid-sized family sedan.
  12. #37
    Apr 2013
    Alabama
    1995 M3 Coupe
    Kenne Bell called today, bad seals. Rebuilding compressor and drive.
    1995 M3...Screwed
  13. #38
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by Jab31169 View Post
    Doesn't look bad. Your putting the same clutch back on it right?
    86 325es, 2.8L m50, S472sxe, MS3pro Ultimate, e85, solid rear axle, 4 link, spool, TH400 trans, Protorque converter, 28x10.5w slicks, zip ties
    Best = 9.43 @ 149.15 mph, 1.30 60 foot 28 psi boost
  14. #39
    Apr 2013
    Alabama
    1995 M3 Coupe
    Yea
    1995 M3...Screwed
  15. #40
    SW Florida
    99-01 M Cpe & Rdts, X5M
    BTDT
  16. #41
    Apr 2013
    Alabama
    1995 M3 Coupe
    Yea my packing job sending out to them was no where near that neat. $20 dollars worth of bubble wrap and boxed, then wrapped in bubble wrap and placed in another box.
    1995 M3...Screwed
  17. #42
    Apr 2013
    Alabama
    1995 M3 Coupe
    So last night was dumb, my fault I guess and I don't know if it matters in the long run or not, we will find out when I put it back together. So I put the motor at TDC based off the timing mark on the crank and slap the timing blocks on the cams. Get the vanos off, get the gears off the cams, tensioner off. Go to remove the chain guide and thats when I saw it. The lobes on #1 were pointing away from each other. So I put everything back together and get the cam lobes were they are supposed to be with the timing mark and now the exhaust cam block will not go on at all, not even close. Its a schrick exhaust cam so I though maybe its just one of the bad ones but I dunno know. I kinda felt like a jackass so I just covered everything and walked away for the night. I'll go again tonight and get everything off and worry about the timing when its ready to go back in the car. Real bummer.
    1995 M3...Screwed
  18. #43
    Apr 2013
    Alabama
    1995 M3 Coupe
    Figured out the timing issue, no big deal once I started thinking about it and using my brain. Got all the sensors and whatnot off the head last night. Head is ready to come off, just waiting on my thin walled torx to come in on Sunday.
    1995 M3...Screwed
  19. #44
    Feb 2012
    1995 BMW M3
    Thin walled torx for what?
    If you mean the one to remove OE head bolts, I got one I can bring ya
  20. #45
    Apr 2013
    Alabama
    1995 M3 Coupe
    Yea thats what I need, but its all good I got it off amazon with CC points. I figure I'll toss it in with benji's cam blocks so whoever borrows it can already have one. Thanks thou!
    1995 M3...Screwed
  21. #46
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by Randy Forbes View Post
    BTDT
    Randy. Always the showoff. Color me jealous.
    1989 535i - sold
    1999 Tiag/Dove M3 - sold
    1998 Turbo Arctic/black - current
    2004 TiAg/Black - Current
    PTE6870 | 1.15 ar | Hp Cover, Custom Divided T4 bottom-mount, 3.5" SS exhaust, Dual Turbosmart Compgates, Turbosmart Raceport BOV, 3.5" Treadstone Intercooler, 3.5" Vibrant resonator and muffler, Arp 2k Headstuds | Arp 2k Main studs | 87mm Je pistons | Eagle rods | 9.2:1 static compression, Ces 87mm cutring, Custom solid rear subframe bushings, Akg 85d diff bushings, 4 clutch 3.15 diff, , Poly engine mounts, UUC trans mounts W/ enforcers, 22RPD OBD2 Stock ECU id1700 E85 tune, 22RPD Big power Transmission swap w/ GS6-53
  22. #47
    Apr 2013
    Alabama
    1995 M3 Coupe
    Cams on the way out:
    Cams, lifters and trays out:
    Head bolt #14....hmmmmmm:
    Heads off:
    Looks like my point of impending failure:
    Head seems to say the same thing:
    Full Head:
    Gasket pulled off block:
    1995 M3...Screwed
  23. #48
    Tanks95's Avatar
    Nov 2002
    North Carolina
    I6 & V8 ///M
    time for cut rings....
  24. #49
    Dec 2002
    Broward, FL
    doh.. i really miss my old car... let me have it back! Even to this day, all of my friends say I shouldnt have sold it.
    great work, by the way.
    -M3J0N
  25. #50
    Mar 2012
    Renton, Wa
    98 m3
    Fuzzy pictures. But i think det marks on the piston and head.
    1989 535i - sold
  1. REBUILD: Done with the Twin Screw, Going TURBO!
    By Tanks95 in forum Forced Induction
    Last Post: 11-29-2016, 11:44 PM
  2. Post-Rebuild Twin Screw Dyno
    By Neil in forum Forced Induction
    Last Post: 02-23-2009, 03:26 AM
  3. Post-Rebuild Twin Screw Dyno
    By Neil in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-18-2009, 09:05 PM
  4. Stimpee's twin-screw
    Last Post: 06-13-2003, 02:58 PM
  5. Whipple twin-screw.... ???
    By NoSoup4U in forum Forced Induction
    Last Post: 05-17-2003, 11:51 AM
