Page 1 of 6 123456 LastLast
Results 1 to 25 of 145
Thread: Rebuild: Better, Faster, Poorer - Twin Screw Edition
    Apr 2013
    Alabama
    1995 M3 Coupe
    So as a few of you know, I have an e36 M3 that I love to beat on. Its had a twin screw supercharger bolted to it for about 20k, of which I've owned it for about 10k of that. It doesn't live an easy life, its my track car. Not a daily but when it comes out to play, it gets put though the ringer. So a few weeks before my last track weekend at barbers, I noticed my coolant hose was holding pressure after 24 hours. When it was running, the hose was rock hard. Searching the forums and the rest of the interwebs,this seems to indicate a head gasket on the way out. I had no oil and coolant mixing, just the pressure. Ran at barbers with no issues. Fast forward 3 months and after the last autox (FTD for me) I get home and I notice that the coolant reservoir appears to be empty. I start to remove the cap and *WOOOSH* all the coolant comes rushing back in. So I pulled the spark plugs and #6 didnt look great. So I made the decision it was time to pull the head. But instead of just pulling the head, I am going to pull the whole motor. I've got some other things I need to get done while its out, so this is just the easiest route for me currently.
    At Road Atlanta (That hill is like driving off a damn mountain):
    At Barbers:
    Cleared 200k on my way back from the last track weekend at Barbers:
    Time to start the tear down
    Getting started:
    Stopping point for the night:
    Next night
    Thats better:
    1995 M3...Screwed
    Mar 2012
    Renton, Wa
    98 m3
    In for results! I wonder if a bigger a/w intercooler would benefit your setup for track use.
    I had a ts kit for a minute and it had 180+ peak intake temps.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Apr 2013
    Alabama
    1995 M3 Coupe
    Quote Originally Posted by vollosso View Post
    Yea, been thinking about a bigger reservoir as well as Water/Meth injection. But looking at the heat exchanger inside of the manifold, I don't know how well the water/meth would do. I'll post some pictures of it later.
    1995 M3...Screwed
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    So what turbo are you going with?
    XD
    Mar 2012
    Renton, Wa
    98 m3
    Ehh those laminova intercooler cores are really efficient. Way more efficient than that front core.
    Tanks probably has data on them.
    If i was tracking a Ts id max out that aw. You could easily fit a 3.5x20x8 ic in there with ac. How does your current compare?
    1989 535i - sold
    Apr 2013
    Alabama
    1995 M3 Coupe
    I'll measure it when I get home. Could stand to be a bit thicker.
    1995 M3...Screwed
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by Jab31169 View Post
    I'll measure it when I get home. .
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Apr 2013
    Alabama
    1995 M3 Coupe
    Twin screw is off, that little focker is heavy (Should of taken the pulley off first but the batteries for the impact were dead)
    Heat Exchanger
    I gotta say, having the front off the car makes all this crap a ton easier. So much room for activities
    Number 4 looks pretty normal, 1-5 look like this:
    Number 6 don't look so good:
    Spark plugs were telling the truth
    1995 M3...Screwed
    Apr 2013
    Alabama
    1995 M3 Coupe
    You ready big boy?
    24x3x6
    Apr 2013
    Alabama
    1995 M3 Coupe
    Leak off the snout:
    Twin Screw boxed up and ready to ship to Kenne Bell:
    Goodies:
    I got bored with the dremel, so I got rid of stuff that isnt needed anymore:
    Injectors shipping off to VAC today:
    Parts shelf is getting full:
    1995 M3...Screwed
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    As a person who speaks in movie quotes, if that is from Step Brothers, I see what you did there...
    Good luck, who doesn't like a fresh rebuild!
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
    Apr 2013
    Alabama
    1995 M3 Coupe
    Quote Originally Posted by BMWManiac View Post
    Okay, here's the shot out of the cannon: Oprah, Barbara Walters, your wife. You gotta bang one, marry one, kill one, go!
    1995 M3...Screwed
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    Would love to see what this kit would make on stock compression with e85
    Apr 2013
    Alabama
    1995 M3 Coupe
    Got the rest of the wiring harness labeled and disconnected from the motor. Went nuts with painters tape and magic marker. Almost free and clear. I've got to drop the exhaust, disconnect one remaining ac line, disconnect the drive shaft and gear shifter. After that should be good to go. Going to pick up the hoist and remove the hood on friday night. I've got training all next week and then the 4th of July. Probably wont get a whole lot done until after the 5th or so. My Zionsville fatboy with oil cooler should hopefully come in within the next week or so.
    1995 M3...Screwed
    SW Florida
    99-01 M Cpe & Rdts, X5M
    When I drop an engine out, I unbolt the compressor and hang it on the inner fender, everything stays charged up.
    Coming out the bottom, you don't have to take as much apart
    Apr 2013
    Alabama
    1995 M3 Coupe
    Quote Originally Posted by Randy Forbes View Post
    Currently debating if I'm going to put the ac back in at all...
    Apr 2013
    Alabama
    1995 M3 Coupe
    You guys ever seen 8qts of oil on a concrete floor?
    Buddy came over to change the oil on his car before he let me take his m3 (eurosport twin screw) to the autox the next day. Handed him my drain pan, we forgot to pull the plug on the pan before we started draining. Two bags of oil dry and 30 mins later it was cleaned up.
    1995 M3...Screwed
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    It's one of those things you will probably do only once.
    Feb 2012
    1995 BMW M3
    When I worked at Firestone I knocked over the portable oil drum and spilled damn near 30 gallons
    Apr 2013
    Alabama
    1995 M3 Coupe
    Quote Originally Posted by rajicase View Post
    I can't even
    poconos pa
    e36 m3, turbo e36
    I had a tech pump 26 qts of oil into a car once that only took 4.5 qts. Oil was coming out of everything!
    This man speaks the truth!
    -sold...replaced by turbo e36
    Apr 2013
    Alabama
    1995 M3 Coupe
    Got my injectors back from vac all freshened up
    Father in law picked up a new ride a few weeks ago
    Jan 2017
    Houston, Tx
    97 M3 Estoril on Dove
    Leave the TS off, box it up, ship it to me, and then you can buy a turbo.
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Must be nice...the luxury of snazzy lifts and such.
    DOH!!!
    Apr 2013
    Alabama
    1995 M3 Coupe
    Fatboy came in with oil cooler...so fat
    Unfortunately there is a slight problem...
    No tabs to mount the cooler combined with the extra large cooler. Already talked to zionsville and they sent me a return label to get the mistake fixed.
    Not much progress to speak of, pulled the midpipe and xbrace off. Thought about pulling the slave and disconnecting the driveshaft but I got a case of the lazy and decided to watch TV instead.
    Midpipe still looks like a work of art
    1995 M3...Screwed
  1. REBUILD: Done with the Twin Screw, Going TURBO!
    By Tanks95 in forum Forced Induction
    Last Post: 11-29-2016, 11:44 PM
  2. Post-Rebuild Twin Screw Dyno
    By Neil in forum Forced Induction
    Last Post: 02-23-2009, 03:26 AM
  3. Post-Rebuild Twin Screw Dyno
    By Neil in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-18-2009, 09:05 PM
  4. Stimpee's twin-screw
    Last Post: 06-13-2003, 02:58 PM
  5. Whipple twin-screw.... ???
    By NoSoup4U in forum Forced Induction
    Last Post: 05-17-2003, 11:51 AM
