Results 1 to 15 of 15
Thread: Question on gas gauge
    Jun 2017
    Pearland, Tx
    1998 BMW Z3
    As I mentioned in an earlier post I just bought my wife a "showroom condition" 98 Z3 Roadster. And she hasn't driven her Nissan 370z since. Anyway I noticed when re-fueling that the gas gauge doesn't ever show full, and I have tried to get more gas in it but the pump handle keeps shutting off.
    So my question is, is this ordinary or might there be a problem with the vent tube?
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    It could be the sending unit, but you don't want to overfill the gas tank. That will cause other issues over time.
    These may help ...
    https://www.bimmerforums.com/forum/s...for-fuel-Gauge
    https://www.bimmerforums.com/forum/s...stuck-on-empty
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
    2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
    2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by SEP1006 View Post
    ... when re-fueling that the gas gauge doesn't ever show full, and I have tried to get more gas in it but the pump handle keeps shutting off.... is this ordinary or might there be a problem with the vent tube?
    Many people in many forums have reported that adding Techron helps the gauge -- possibly by freeing the sender of gum or cleaning its resistor card contacts of corrosion. Run the tank down, put in a double dose, fill up, and see if it helps.
    "... TECHRON Concentrate Plus is formulated with a deposit control additive which can clean sulfur corrosion, a possible cause of fuel gauge malfunction."
    http://www.oreillyauto.com/site/c/de...1279/N0407.oap
    Over-riding the gas pump shut-off on a full tank does not affect the gauge, and can put gas into the evaporative vent system and cause an emissions code.
    BMW MOA 696, BMW CCA 1405
    Jun 2017
    Pearland, Tx
    1998 BMW Z3
    Thanks for the responses and I guess it's not a big issue just an annoyance. I'm going to let the tank get close to empty and then refill with the added techron as suggested. I'm curious to see how many gallons it will take before the fuel nozzle clicks off.
    Jul 2013
    Boston, MA
    1997 z3 2.8
    I just got my Z3 a few weeks ago and I have the a similar problem in reverse: My gauge is stuck on full. I reset my trip odometer to look at miles. I drive mostly around town and did 110miles before refilling it and put in 6.5 Gallons, so I'm guessing I can go 180miles safely without running out of gas. I had some seafoam on hand and used that to see if it will clean it. Once I work through this tank, if that did not work, I'll try out the techron.
    Mesa, Arizona
    2000 Z3 M-Roadster
    Something similar happened to me. I thought this was an issue related to a stuck gas gauge and/or sender not reading what I thought was a full tank, the issue was related to a bad shutoff (purge) valve.
    May 2017
    NW Indiana
    2000 BMW Z3 M Roadster
    My 2000 M Roadster's fuel gauge shows full after a fill up. If anything, it seems to show 1/2 full after ~200 miles, then it drops pretty fast. I can get ~300 miles on a tank, but usually fill it after 200-250 miles. My low fuel light does come on around 1/4 tank.
    Tally Ho
    http://wcwebs.net/johnson
    1988 O'Day 322 sailboat - (unlimited mpg)
    2000 BMW Z3 M Roadster (25 mpg - but who cares)
    2019 Subaru Outback
    (30+ MPG)
    Oct 2012
    Louisville, KY
    Quote Originally Posted by potxoli View Post
    ... I had some seafoam on hand and used that to see if it will clean it. Once I work through this tank, if that did not work, I'll try out the techron.
    I think Seafoam lacks PEA, polyether amine, an ingredient found in most of the other fuel system cleaners like Techron, Red Line SI-1, Amsoil Pi, and Gumout Regane.
    Jul 2013
    Boston, MA
    1997 z3 2.8
    Quote Originally Posted by Vintage42 View Post
    Good to know. I will get some techron for sure. My list for Autozone is increasing by the day
    Mesa, Arizona
    2000 Z3 M-Roadster
    I prefer BG 44k for a fuel system cleaner
    Lawrenceville, GA
    4 BMWs.
    what is a 2007 Z3? Z3 model years are 1996-2002.
    Jul 2013
    Boston, MA
    1997 z3 2.8
    I don't know what you are talking about... Just kidding, thank you for the feedback. Typo on my profile. My Z3 is a Jan 1997 build date.
    Lawrenceville, GA
    4 BMWs.
    It's all good. Just bringing it to your attention!
    Oct 2012
    Louisville, KY
    Quote Originally Posted by ProductUser View Post
    It also has PEA.
    "Chevron Techron Concentrate Plus (or similar known PEA-containing (polyether amine) fuel system cleaner products like Gumout Regane, Redline SI-1, Amsoil Performance Improver, and BG Products 44K)"
    -- a few posts into this thread:
    https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1865221
    Jun 2017
    Pearland, Tx
    1998 BMW Z3
    That's kind of what I was thinking. Once the tank gets empty I will re-fill and add techron, just curious to see how many gallons it shows that I put in.
  1. Question on Temp Gauge
    By dhawthorne15 in forum 1976 - 1989 (E24)
    Last Post: 08-11-2009, 03:32 AM
  2. Question on Gas.....
    By Nicci in forum 1999 - 2006 (E46)
    Last Post: 10-31-2005, 10:48 PM
  3. Quick question on Gas Guage and Sending Unit.
    By Mantic in forum 1992 - 1999 M3 (E36)
    Last Post: 07-29-2005, 03:16 AM
  4. Quick question on Gas..
    By WCM3 in forum 1991 - 1999 (E36)
    Last Post: 07-14-2005, 08:07 PM
  5. question on VDO gauges
    By mredwin25 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-04-2004, 12:58 PM
