Results 1 to 25 of 26
Thread: Fishtailing rear end
    Sep 2015
    Lansing,MI
    2000 BMW M Roadster
    I have a 2000 M Roadster with 54,000 miles on it. Tires are new Michelin Pilot Super Sport. When driving normally, on a straight road, the rear end of the car starts fishtailing at around 50 - 60 mph and seems to get worse as speed increases. Steering doesn't seem to be affected but the fishtailing is violently felt in both driver and passenger seats. I don't see any evidence of rear subframe separation...the spot welds in the trunk floor look good.
    I'm not sure what to look for and will appreciate any help in diagnosing this problem.
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    Did it do it before the tyres were fitted?
    Joppa, Md
    99 M Coupe,04 K1200rs
    My 99 coupe would tramline terribly, frightening in the wet over 40 mph.Still not sure why.
    Huntingdon Valley, PA
    2018 X4 M40i
    When was the last time you had the suspension aligned?
    I have a '98 M with the same tires. I had some rear tramlining yesterday over some tar seams in the road where the rear wiggled a bit, but that was at 25 MPH. If you are having that happen at 60, you need to see what's up with the rear end.
    Have you replaced the rear shock mounts yet?
    2018 X4 M40i
    Sep 2015
    Lansing,MI
    2000 BMW M Roadster
    Yes, but maybe not as noticeable. I have put on only a few hundred miles with new tires.
    Suspension was aligned when new tires were installed...maybe 300 miles ago. I have not yet replaced rear shock mounts... as far as I know suspension is all original.
    2018 X4 M40i
    How many miles on the suspension? Assuming it's all 16-17 years old, you may be seeing the results of grippier tires pulling at worn out points. When I bought mine the rear shocks were shot (at 109K miles) and at a certain speed the rear end had a rotory sensation, sort of like J.Lo walking down the street. New RSMs and shocks (among other things) solved the problem.
    2018 X4 M40i
    Feb 2017
    Suburbadelphia, PA
    1997 Z3 2.8 Roadster
    Quote Originally Posted by Telecomtodd View Post
    If that kind of expense is necessary to correct a J.Lo sashay...how much would it cost if the rear action resembles that of Nicki Minaj?
    2018 X4 M40i
    Beacoup dollah, boyyyyyy.
    2018 X4 M40i
    SW Florida
    99-01 M Cpe & Rdts, X5M
    I'm crying here, stop it!
    Two (2) points: brand new tires definitely have tread squirm, from the tall tread blocks, and I very recently replaced the shocks on a 37,000 mile virgin '99 Coupe and they were totally shot__virtually no resistance whatsoever to compress/extend their shafts (they had been used for an undetermined amount of time with H&R springs).
    In the past, I've publicly stated that the OE M shocks were toast by 42,000 miles (amazes me the number of cars I see with excess of 100k on original suspensions ); I think it's time to revise that number downward! Konis are my recommendation: good ride and xlnt control.
    Jun 2005
    Lincoln, NE
    E34, E36, E36/7
    slightly OT but will original shocks show as SACHS on the tube? I was under the 137k 2.8 roadster i just purchased and they looked pretty untouched.
    13 Grand Cherokee Limited V8 - Daily Driver - Wife
    97 Z3 2.8 Roadster
    95 325i Sedan - Project #ebayE36
    90 BMW 535i/5 - i should probably work on this again...
    Jul 2010
    Philadelphia, PA, USA
    2001 M Coupe, 2002 M3
    Before you even get into all of that, have you looked at the most simple causes of vibration?
    I know the OP said "fishtailing," but is it truly fishtailing, meaning the back end does not maintain traction, or does it just feel "loose?"
    Bent wheels first, then alignment. Depending on what is found in the alignment, bent suspension arms or needs bushings or mounts.
    Original bushings on a 17 year old car will be in need of replacement. Rubber ages, no matter the storage conditions or mileage.
    Jul 2004
    Houston, TX
    36 Cylinders
    Can you post your alignment specs?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Redding Calif
    1999 Z3 2.5L 5sp
    Data is always a good place to start...
    wondering if he's ended up with a bent trailing arm and has a toe or asymmetric camber problem.
    Quote Originally Posted by lpschafer View Post
    When you're sitting at a standstill - engine off - but key in and turned so the steering wheel is unlocked: how much play do you have in the steering wheel at the rim? None? Small fraction of an inch? Or you can rock the wheel back and forth more than a fraction of an inch? ... what I'm thinking, is that you might have a lower steering column flex disc that's gone, a steering box that's gotten loose, or a rod end that's become likewise? ... I'm assuming that when you say fishtailing, that you're not actually losing traction in the rear, but the car is wandering left then right then left etc... that can be caused by asymmetric alignment front or rear, or by loose steering system components.
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
    Quote Originally Posted by Randy Forbes View Post
    Sorry (180k miles, bought about a year ago). I swear the reason I'm just finishing replacing mine is because everything else is also old! (maybe also because I totaled it and had to get it rebuilt).
    Too bad you probably don't have a frame alignment machine, I'd make a trip to FL for someone I could trust.
    SW Florida
    Quote Originally Posted by LannVouivre View Post
    For some perverse reason, I wish I did have a frame alignment rack!
    Not so much to un-pretzelize a car/chassis, but for the sake of alignment checking. Could you imagine some future purchaser of my house/shop, wondering why there's a 5' x 12' x 1' (preferably Starrett) granite slab in the garage...
    If only those things were free
    Jun 2016
    Odessa, TX
    "Incomplete bomb shelter," or, "I got it for free from a dumpster," or, "I'm *really* in to metamorphic rocks..." I suspect any of those would fly better than, "I did automotive body repair out of my garage." I think a lot of people are a bit touchy about "amateur" (you're a professional) auto repair.
    2018 X4 M40i
    Incomplete bomb shelter...found one of them in St. Louis in the basement of a house we were looking at. Looked up at the ceiling and could see the paint had lightly covered "fabric". What kind of "fabric" would you put in a bomb shelter built in the 50s? Asbestos, of course! Passed up that deal...
    2018 X4 M40i
    Mar 2003
    somers,ny
    any pics or vids of that JLo stuff?.......lol
    Oct 2013
    Rock Hill, SC
    2000 BMW M Roadster
    Maybe you got a bad alignment?
    If you were happy with how it drove and they changed the alignment, then it is going to drive differently afterwards (either better or worse). Did you get the before and after alignment specs?
    2018 X4 M40i
    Quote Originally Posted by jrkoupe View Post
    2018 X4 M40i
    Sep 2015
    Lansing,MI
    2000 BMW M Roadster
    Sorry this has taken so long...I've been away from home. Here are alignment specs:
    Left Front: Camber = -1.0 Caster = 7.1 Toe = 0.16
    Right Front: Camber = -0.9 Caster = 7.7 Toe = 0.17
    Left Rear: Camber = -1.6 Toe = 0.88
    Right Rear: Camber = -1.1 Toe = 0.23
    Mar 2003
    somers,ny
    your rears are kinda not equal?????????........that could be fishy...no pun intended
    look how equal your frts are.......
    Oct 2003
    Seattle
    99 M3
    Total toe and cross Toe looks outa wack.
    But how are your rear control arm bushings?
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Subframe bushings? My 98 Z3M, with 90k on original SF bushings, did some odd moves over uneven pavement. With IE subframe bushings, it didn't do that anymore. I hadn't realized how bad it was until I felt the new bushings. The manners of the car got better in every way. It feels like the rear tires now follow the front tires, like they are supposed to. I think every Z3 should have IE subframe bushings.
    Ahh, see, there is a fatal flaw in your logic... you see, my friend, granite is an igneous rock, not metamorphic...
    PRICE CUT on ALL FABRICS
  1. Leaky Rear End
    By E36 Fanatic in forum 1991 - 1999 (E36)
    Last Post: 02-07-2002, 02:59 PM
  2. Got Rear-ended
    By JayT in forum 1992 - 1999 M3 (E36)
    Last Post: 10-12-2001, 09:02 AM
  3. strange clicking from rear end...
    By Digitalwave in forum 1983 - 1991 (E30)
    Last Post: 09-28-2001, 10:56 PM
  4. Clunking noise from rear end at track event...
    By Cannon in forum 1992 - 1999 M3 (E36)
    Last Post: 05-22-2001, 02:33 PM
  5. Got rear ended today....... Need Help
    By Spencer in forum 1992 - 1999 M3 (E36)
    Last Post: 04-06-2001, 02:48 PM
