Results 1 to 25 of 28
Thread: Just put 3.64 in my '97 840ci and HOLY CRAP
    Aug 2003
    Woodinville, WA
    '87 L6, '97 840, '02 M5
    This is probably the single most noticeable mod I've done on any car.
    I did a lengthy post comparing my '94 850ci and my '97 840ci and in the end, I felt they were about the same around town, with a nod to the 840, but in sport mode the 850 was a much faster car.
    Well, no longer. I finally got around to installing a set of 3.64 gears from dragon850 and now it's not even close. The 840 is an absolute beast - while not as fast as my e39 M5, it sure feels like it would keep up. I know that sounds like a bunch of BS, but I can tell you that gear change completely transformed the car. From a stoplight, in Sport mode, I have to be careful because if I hit the throttle the car leaps off the light.
    If anyone has an 840 they feel is a little slower then they would like, DO THIS SWAP.
    I've done a lot of gear swaps, a lot of chips in my time, but nothing is as night-and-day as this has been. I'm in love with my 840 all over again.
    1987 L6
    1997 840ci
    2000 740i Sport
    2000 M Roadster
    2001 M5
    2002 540i Sport
    2002 X5 4.6is
    2003 530i Sport
    2003 M3
    2003 Z3 3.0
    2005 X5 3.0 Sport
    Sep 2010
    Finland
    bmw 850i M-tech
    Can you say what is the difference in acceleration at 0-62 mile/h ?
    Anacortes,WA
    E34 535i; E36 325is
    What donor BMW cars can the 3.64 diff be taken from?
    Indianapolis, IN
    93 850Ci, 09 Caddy SRX
    Quote Originally Posted by Dash01 View Post
    Early 850's with the 4spd auto transmission.
    1993 850Ci.....18 years & 165,000 miles and counting!
    Nov 2005
    Langley BC Canada
    91 850 Panzer
    Have 3 or 4 3.64 open diffs here - straight bolt in as they came from early 850s Drive up from Anacortes and pick one up!
    wuffer at shaw dot ca
    91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
    Feb 2009
    Hernando, Mississippi
    E82, E71, 1996 318ti M
    I also have a 3.64 open diff from an early 850. Shoot me a PM if interested.
    dancerst's Avatar
    dancerst is offline life is a dance... BMW CCA Member
    Virginia Beach, VA
    E36 SC,E31 840ci,740iL
    I have 3.64 Limited Slip Differential for sale.
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Hehehehe how did this turn into a "for sale" thread?
    Canada
    95 BMW 850
    My car seems pretty fast off the line. It's an M73 press car so maybe they put in a 3.15 diff. Probably not. It runs at 110 kph which the computer says is 103 kph at 2000 rpm. It has the correct size tires.
    It would be nice to lose 50 kilos up front as it doesn't like quick downhill cloverleaf exchanges.
    Nov 2013
    Whitney, TX
    97 850CI
    I changed the 3.15 LSD that came in my 97 850 for a 3.64 LSD. Definitely worth the effort.
    Desecrator of all things Sacred
    May 2013
    Salinas CA.
    1993 BMW 850CI
    You are all baaad boys! The rear differential gear change to 3.64 turns an 840CI into a Very fun car! I helped a buddy swap the differential from my 93 850CI into his 94 840CI, and he just Loves it. One thing to be aware of is that there are different differential input yokes. We had to swap his onto mine, and that takes an air impact, and a bit of skill. Is it worth it? Absolutely! What did I put into my 850CI which has the 4 speed auto you might wonder. A Jim Blanton built 4.10 BMW Motorsport gear limited slip! Yes, I do like it, 3000 RPM at 80 MPH, hits 120 MPH very quickly. Enjoy the 8^ madne$$.
    Sep 2010
    Finland
    bmw 850i M-tech
    Quote Originally Posted by Mikekugel View Post
    How quickly?
    I think that 3000rpm is a bit too much, since eight will always be a slow car now matter what.
    May 2013
    Salinas CA.
    1993 BMW 850CI
    To each their own, but 3000 RPM at 80 MPH is just fine by me. Most USA speed limits at best are 80 MPH. My car is DINAN chipped which raises the torque peak to about 3400 RPM. When I punch it to pass the transmission drops out of overdrive into 3rd gear, and that raises the RPM to around 3400, and the car moves very quickly, with 100 MPH in about 4-5 seconds, and 120 in about 10 seconds total. It is a heavy car, but it can still move very quickly with the right rear gear ratio. The trade off is lower fuel economy on the highway. The all around performance increase most likely makes a differential swap the best bang for your money. Search for all the guys who have done the 3.91 ratio swap.
    As an aside, before I decided to swap the differential, I installed Euro M-Sport springs all around, removing the Eibach Pro kit, I have EDC, now it handles very well, and I love the balance. I also installed CSI sway bars, and replaced every rubber bushing from front to rear, and sub frame to body.
    My Infiniti G37s coupe is a much more fun car to push very hard, but it isn't a classic car! I have driven Tesla Model S P85d, and owned several other fast cars. I prefer to go to the race track for fun.
    Aug 2003
    Woodinville, WA
    To backup Mikekugel.
    First, if you're a high-speed driver, then maybe this isn't your mod. If you care about fuel economy, this isn't your mod.
    Also, fast is relative. There isn't a BMW of this era that can compete with a damn FOCUS ST these days. So yeah, they are all slow, sure.
    However, I'd argue this shaves .5 or more off the 0-6 times which certainly makes it quick. And the improvement is dramatic over stock.
    So for me, where this is a causal driver - mostly around-town with short highway trips, this has made the car EXPONENTIALLY more fun to drive, quicker off the stoplight, and feels a lot closer to my e39 M5 and my e38 740i m-sport then previously, where it was by far the slowest of my V8 BMW's.
    Just ordered a GPS G-tech so I'm gonna do some 0-60 runs with my cars and see how they compare.
    1987 L6
    1997 840ci
    2000 740i Sport
    2000 M Roadster
    2001 M5
    2002 540i Sport
    2002 X5 4.6is
    2003 530i Sport
    2003 M3
    2003 Z3 3.0
    2005 X5 3.0 Sport
    Sunny Cali,
    6.5 second 69 Camaro
    Have your DME and TCM flashed to a Stage 5 if you want to experience the next level of FUN.
    Aug 2003
    Woodinville, WA
    Quote Originally Posted by 8eights View Post
    Please explain!?
    1987 L6
    1997 840ci
    2000 740i Sport
    2000 M Roadster
    2001 M5
    2002 540i Sport
    2002 X5 4.6is
    2003 530i Sport
    2003 M3
    2003 Z3 3.0
    2005 X5 3.0 Sport
    Sunny Cali,
    DINAN PERFORMANCE SOFTWARE
    1/96-8/98 Engine Software Download D900-447 C $499 5 units
    <1>
    1/96-8/98 Stg 2 Engine Sftwre Download D903-4472 C $599 5 units
    <1>, (1)
    9/98-01 Engine Software Download D900-447TU C $499 5 units
    <1>
    9/98-8/99 Stg 2 Engine Sftwre Download D903-447TU2 C $599 5 units
    <1>, (1)
    9/99-01 Stg 2 Engine Sftwre Download D903-447TU2 C $599 5 units
    <1>, (1)
    9/98-8/99 Stg 3 Engine Software D903-447TU3 C $699 5 units
    <1>, (3)
    9/99-01 Stg 3 Engine Software D903-447TU3 C $699 5 units
    <1>, (3)
    1/96-8/98 Stg 4 Engine Sftwre Download D903-4474 C $799 5 units
    <1>
    9/98-01 Stg 4 Engine Sftwre Download D903-447TU4 C $799 5 units
    <1>, (11)
    9/98-01 Stg 5 Engine Sftwre Download D903-447TU5 C $999 5 units
    <1>
    1/97-01 Auto. Transmission Download D902-44A5 C $349 5 units
    1/97-01 Stage 4/5 Trans.Software D902-44A5-4 C $349 5 units
    96-12/96 Auto. Transmission Chip $349 8 units
    The prices are cheaper now, These are based on 9 years ago.
    Nov 2013
    Whitney, TX
    97 850CI
    Are you suggesting that Dinan has these software upgrades available?
    Sunny Cali,
    Unless they stopped recently, Got a trans and engine flashed in late 15
    Nov 2013
    Whitney, TX
    97 850CI
    Email sent to Dinan.
    San Jose CA
    1991 850i S70 6 speed
    Dinan is a very different company than they were in 2015.....not better or worst, just a different way of doing business. They are very very corporate now.
    Dec 2018
    Helens Bay
    635d, 640d cab, 840ci
    What was your 3.46 diff out of? Will an e32 3.46 diff fit the 97 840ci auto?
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    I don’t know why anyone wastes money on Dinan stuff. Maybe if it was a new car and you wanted to keep your warranty but it’s over priced and super conservative otherwise.
    Sep 2010
    Phoenix
    840ci/540i/540i Touring
    Pardon my ignorance in all this but what cost are ya all taking about? Is this a home-garage DIY project?
    Sunny Cali,
    Yes! And you can do it without a lift
  1. Want to put cd player in my 97 528i
    By eldonfontenot10 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-23-2012, 02:31 PM
  2. I just put aluminum mesh in my kidneys!
    By VOLSBimmer in forum 1991 - 1999 (E36)
    Last Post: 06-12-2002, 01:41 PM
  3. Can I put m3 springs in my 97 328i?
    By mrdenial in forum 1991 - 1999 (E36)
    Last Post: 05-20-2002, 12:30 AM
