Hey guys,
I am having some window issues. All windows stopped working. Pulled the door cards and checked the fuse box.
1. Fuse is good. #14 30 amp.
2. Regulators are good.
3. Motors are good.
4. Switches are good.
What else could cause this?
Thanks for any help.
If both windows are not working, that points to a GM(ZKE). When you removed the door panels, did you test the wires at the motors to see if they are getting 12 volts when the switches are being pressed? Is the window drop function working when the doors are open and closed?
Sorry for the late response. Was waiting to get my power probe. I reset the battery and the window drop function DOES work. Does this tell me anything? Going to test all points with the power probe soon.
I knew the switches were good because I hooked them up to a power source and a light bulb to troubleshoot, same with the motors.
So! Turned out to be fuse 43 (central locking, GM, etc) which didn't look blown but the power probe got it. All fixed. Thanks for the help, this is my first time on this forum!
