Results 1 to 7 of 7
Thread: E36 Tire Clearance With Camber Shims
    May 2015
    Cherry Hill/Piscataway,NJ
    '87 325, '98 328i Sedan
    Just threw on some fresh Koni SA's and Eibach Pro-Kit springs on my 328i. With a 225/45 on a 17x7.5 et41 wheel do you think I will have clearance issues with the top of my tires and my front struts if I shim for ~2-2.5 degrees of camber?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    No, not with those narrow wheels and tires. I needed spacers with 17x8.5 ET41 and 255/40/17, though just barely.
    May 2015
    Thank you!
    May 2015
    How thick are the shims that you are running?
    Jun 2005
    New England
    I am not using shims. Have -2.5 from plates up top.
    Aug 2013
    1999 BMW M3 Coupe
    You should have plenty of strut clearance using those stock M3 wheels/tires. If you want to go wider you'll need a small spacer to clear the strut. There's loads of fender clearance out front to play with; a 255 on a 17x9 will fit with a spacer and no other modifications.
    May 2015
    I did some calculations and it seems as though I should have between 0.1 and 0.2 inches of clearance with -2 degrees of camber. I will follow up with exact alignment specs and the final clearance.
  1. E36 M3 coilovers with camber plates great shape - SOLD
    By slytherin in forum Suspensions, Springs & Shocks
    Last Post: 06-24-2013, 05:18 AM
  2. E36 E36 Sport rim with worn out tire in Simi Valley CA
    By The Arp in forum Wheels and Tires
    Last Post: 02-27-2011, 12:01 AM
  3. Tire Clearance After Installing Camber Shims
    By CoolDad in forum 1992 - 1999 M3 (E36)
    Last Post: 09-06-2010, 02:06 AM
  4. E36 FS: E36 M3 contours with tires OEM BBS
    By Jmannumber7 in forum Wheels and Tires
    Last Post: 05-14-2010, 06:12 PM
  5. FS: E36 RTAB's with GC Shims
    By Tj Hunter in forum Suspensions, Springs & Shocks
    Last Post: 09-19-2007, 01:13 AM
