Bilstein PSS linear conversion kit Ground control camber plates, Hyperco springs Koni adapters
Hi guys, I pieced this kit together because I thought I needed these to fit my wheel and tire specs with PSS9s. Turns out I don't need them. Rather than take apart a perfectly good set of pss9's, I am going to sell these an get camber plates that accept the PSS9 spring.
You'll get everything shown...
Ground control street camber plates for non tapered, 14mm struts such as Bilstein's - 75 miles before the PO pulled them and sold them to me. The perch accepts 2.25 coil springs. In case you don't want to run 2.25 springs, I am including koni 2.25 to 2.50 adapters. These allow the 2.50 spring to seat perfectly snug on the plate without play. So with these you can run 2.25, 60mm or 2.50 springs. All possibilities.
lastly the springs are Hyperco 5.5 inch springs, 550lb 2.50 diameter. After research, this is apparently an excellent spring rate for the kit without a downside.
The plates are $350+ S/H, the springs are around $130+S/H for the pair and the adapters were $20. That's $500 plus shipping.
I'm asking $490 shipped. Everything is in EXCELLENT shape! Also all parts are boxed up ready to go, nothing needs removed so no wait time.
PRICE IS FIRM - prefer not to separate.
Buyer pays all additional fees, pay,panjo etc...PM me or text me to purchase!
List Date: 6/17/2017
For more info, click here to view the original listing: Bilstein PSS linear conversion kit Ground control camber plates, Hyperco springs Koni adapters
This item is no longer available.
Incase you saw this earlier when I accidentally had two prices listed, I am asking $490.00 shipped, NOT $550.00. My mistake for the mix up.
$490.00 shipped is the price.
