Eibach Coilover Springs
Brand:Eibach
Manufacturer's Part Number:0800.225.0550
Part Type:Coil-Over Springs
Product Line:Eibach Coil-Over Springs
Coil-Over Spring Inside Diameter (in): 2.250 in.
Coil-Over Spring Inside Diameter (mm): 57.15mm
Coil-Over Spring Length (in): 8.000 in.
Coil-Over Spring Length (mm): 203.20mm
Progressive Rate Spring: No
Coil-Over Spring Rate (lbs/in): 550 lbs./in.
Notes: Block height: 3.740 inch, Load at block height: 2,343 pounds, travel is 4.260 inch.
$50 obo
List Date: 6/17/2017
For more info, click here to view the original listing: Eibach Coilover Springs
This item is no longer available.
