Results 1 to 2 of 2
Thread: HELP! TCS, ABS, and RED BRAKE light after changing rear pads and brake sensor
    Jun 2017
    Ohio
    2004 325CI
    Today I changed out my rear brake pads and rear passenger side brake wear sensor on my 2004 325CI Manual Coupe. After putting everything back together I've got my traction control light, orange ABS light and RED BRAKE light on.
    I've looked around the forums before posting and wasn't able to find anything similar to my situation with a RED brake light.
    My brake fluid is at max and my hand brake works just fine now.
    So far I've tried stomping the brake to lock them up(worked for a guy to get ABS to kick in and take the lights off in another thread) spinning the tires for an excessive amount of time(also worked for another guy) and I've restarted the car quite a few times on my way to work.
    If anyone has any other suggestions or ideas on what could've caused this after changing my pads, I'm completely open to hearing them.
    Going into work and wont be able to respond for a while so thanks in advance to anyone who comments!
    dworthy's Avatar
    Nov 2010
    Baumholder, Germany
    05 325it 05 M3 95 318is
    Welcome to the Forum!
    Well the best way to find out is get the ABS/DSC ECU scanned, that will tell you what's wrong for sure.
    My first thought is when you pulled the sensor, you accidentally unplugged the ABS sensor. This will set those lights on, also did you open a bleeder valve?
    Darin
    Current:
    05 M3 Imolarot II(405)/Gray(N5TT) ZCW, ZPP 6sp Manual C.F. Lip, CSL diffuser, Euro Infra-Rot front windshield and a trunk liner! Mr. Go_Fast Stored for the Winter
    Past:
    95 318is Montreal Blue Met (297)/Beige(K1SN) A Hooptie!
    84 M535i gray market Burgandy Rot Met/Black Leather Lowered by Intrax on bilies, poly everywhere, B&B cat back system, K&N, and a hitch! Da Beast - Still running w/375k+!
    91 316i euro Tizianrot/Gray cloth - E-36 w/M-40 motor, such a beater, but great on gas! Best was 38 MPG
    79 525 euro Green/Green RIP
    M-Flight Member
  1. Replies: 1
    Last Post: 07-24-2015, 10:47 AM
  2. Replies: 9
    Last Post: 02-28-2014, 08:53 PM
  3. Low speed brake squeal after installing new pads and rotors
    By razingkane in forum Z3 (E36/7, E36/8)
    Last Post: 03-23-2011, 11:55 PM
  4. Replies: 2
    Last Post: 12-18-2008, 08:19 PM
  5. Brake light still on after installing new pads and sensor???
    By SteveL in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-19-2007, 11:53 AM
