I'm trying to code injectors on my 2008 523i E61 but I get the following error:
ApiResultText: Error #100
API job error or no such result!
Continue script processing?
Below is a picture of the K+DCAN cable I'm using:
I used 3 different guides for setting up INPA, the last one being a ready VBOX image from E90post forum. All 3 guides took me as far as seeing both battery and ignition are ON, but all ended up with the same error as above when I try to follow the injector coding options.
Help! I'm stuck on this for days. Thanks in advance.
