Results 1 to 9 of 9
Thread: Will these wheels still work?
    Oct 2015
    Merrillville
    2003 M3
    Bought some rims online and forgot to change the rear rim size. So now I own 4 that's 19x8.5. The place I ordered them from don't have the 19x9.5 available. I can return them but it's a 300 buck restocking/shipping fee. Can I make what I have work?
    dworthy's Avatar
    Nov 2010
    Baumholder, Germany
    05 325it 05 M3 95 318is
    Do you know the offset?
    Yes you can have a square set-up, but normally that is on the winter tires.
    Anywho, if you do stick with those rims, I would run a 235 45 R-18 all around, otherwise if you go with 2 different sizes, it may give it a "fat" look. The plus would be that you could rotate the tires for a more even wear.
    The other option would be to go with the 235's up front and 245 45 R-18 in the back. You really won't see much of a difference unless you look real close.
    Darin
    Current:
    05 325it Electric Red(438)/Gray(N6TT) ZCW, ZSP 5sp Manual Back set cover, trunk mat, Euro Infra-Rot front windshield, and mud flaps! Mr. Wagon (Original Owner)
    05 M3 Imolarot II(405)/Gray(N5TT) ZCW, ZPP 6sp Manual C.F. Lip, CSL diffuser, Euro Infra-Rot front windshield and a trunkliner! Mr. Go_Fast (Stored for the Winter, 2nd Owner)
    Past:
    95 318is Montreal Blue Met (297)/Beige(K1SN) A Hooptie! (10th Owner; That is what happens when it gets passed around by Soldiers!)
    84 M535i gray market Burgandy Rot Met/Black Leather Lowered by Intrax on bilies, poly everywhere, B&B cat back system, K&N, and a hitch! Da Beast - Still running w/375k+! (2nd Owner)
    91 316i euro Tizianrot/Gray cloth - E-36 w/M-40 motor, such a beater, but great on gas! Best was 38 MPG (2nd Owner)
    79 525 euro Green/Green RIP
    M-Flight Member
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Quote Originally Posted by RamontG View Post
    Hello and welcome to the forum! I'm attaching a really helpful guide on wheel fitment and spacing/offset. It's quite comprehensive, but very easy to understand and useful to know. Hope this helps!
    Wheel Fitment & Spacing Guide
    888.280.7799 | 6am - 5pm PST
    Oct 2015
    Merrillville
    2003 M3
    Hey. Thanks for the response. The offset is +30. Do you mean r19?
    dworthy's Avatar
    Nov 2010
    Baumholder, Germany
    No, it will be E-30, or begin with "E" The -30 means 30mm to the outside off center of the drum.
    Darin
    Current:
    Past:
    M-Flight Member
    Oct 2015
    Merrillville
    2003 M3
    dworthy's Avatar
    Nov 2010
    Baumholder, Germany
    ET-40 should be just fine, but you will see the rears may look a bit funny as it will be sucked into the wheel well a bit.
    Darin
    Current:
    Past:
    M-Flight Member
    Oct 2015
    Merrillville
    2003 M3
    Yea. Been doing some searching and I see that they will be sucked in a bit. Was thinking about maybe using spacers. Probably just best to take the loss and send the wheels back though. Expensive lesson learned that's for sure. Thanks for all of your help!
    dworthy's Avatar
    Nov 2010
    Baumholder, Germany
    The question is, how much will the spacers cost vers sending the wheels back? And do you think you will like having the square set-up?
    Actually I think you would be better served to send them back and get a staggered set-up, and that way you can have the proper sizes without having to piecemeal it together.
    Darin
    Current:
    Past:
    M-Flight Member
  1. Will these wheel sizes work?
    By nrowensby in forum 1996 - 2003 (E39)
    Last Post: 06-28-2010, 02:43 PM
  2. will these wheels work...yes i checked bmwe34.net
    By iwantanm5 in forum 1988 - 1996 (E34)
    Last Post: 04-14-2010, 12:53 PM
  3. Will these wheels work on a E36 M3?
    By E36M3Project in forum 1992 - 1999 M3 (E36)
    Last Post: 06-05-2009, 12:24 AM
  4. will these wheels/tires work?
    By speedpg in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 12-29-2008, 04:55 PM
  5. Will these wheels work on my 2005 325i?
    By r0gue in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 12-05-2008, 07:42 PM
