Hi guys
I just bought used X1 (2012). As I m new to bmw world, I have few questions (goes as follows). I will be grateful if anyone can help/guide.
- coding- I succeeded in coding few things using carista app but I m not able to find option to fold side view mirrors using key fob. Any ideas where I can do it from?
- app for coding- as mentioned above I used carista But I m confused if I used buy Carly or bimmercoding. If anyone who experience with both or either can share there views or guide/suggest!.
- it's been two weeks since I had this car but I discovered just today that the tires it came with are non runflat tires. I m also curious will it effect the sensors/air pressure monitor to monitor air pressure ? I mean will it still be able to check air pressure??
- wiper water nossel-- left one seems to be blocked. Tried removing water pipe to check if it is not blocked but it's not. Now I can't find anywhere on how to remove/detach the nossel to clean. Tried thin wire too but no luck.
Jitin Sharma
I am not familiar with aftermarket coding devices however- check to see if your vehicle does have the power folding mirror option.
Runflat tires have no effect on your Tire pressure monitoring system. On an X1 you have TPMS or RDC system and it watches pressure and temperature. A runflat tire and a non runflat tire will read the exact same to the sensor when at the same pressure.
use compressed air and blow into the nozzle, or you could have a split line under the hood
Hi, are you still having issues with the coding of auto-folding mirrors? I'm the creator of Carista and if that setting is not showing up for you, we should definitely fix that. Feel free to PM me or reply here (or email the support email).
