Results 1 to 8 of 8
Thread: Gear lever issues - 328i E46
    Jun 2017
    Gaborone, Botswana
    328 ci
    Hey guys my auto 328ci do not shift into park, it will go into all other gears, however it feels like something is in the way when you go to shift into park
    Also I cannot get my keys out.... ' What might be the problem
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Is that an E46 model? Built year, month? You can find that out here with your VIN www.realoem.com
    EURO spec car?
    Jan 2016
    Ca
    2001 525it
    Coins or crap in the shifter won't let it move forward enough?
    It wont let you remove the key unless the car is in P (on some cars you can remove in N)
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    If it's not something in the console (coins, etc) as jclausen suggested, it sounds like the cable is the problem. This likely will need to be on a rack to inspect. What year is the car and how many miles?
    Discussion has been re-titled and moved to E46 sub-forum.
    88M3 AW 43k miles Project FS
    Jun 2017
    Gaborone, Botswana
    328 ci
    Quote Originally Posted by BimmerBreaker View Post
    So I need to take it for inspection. its a 2000 model e 46, 328ci. How can I check if its not coin or crap trapped there
    Jun 2017
    Gaborone, Botswana
    328 ci
    This E46, 2000 model 328ci. It millage74000 km (46500 miles) So I have to take it for underneath inspection? So this can not be caused by low gear box oil?
    Osnabrock, ND
    2004 325xi,2004 545i SMG
    pull shifter handle off and remove boot and look under there. I bet there is something jamming the works. like coins. people put coins in ash tray and over fill, coins slide out and down where shift lock is.
    start there. you should be able to lift shift lock with screwdriver and put shifter into park and remove your key then
    Level 1 Certified BMW tech.
  1. Replies: 6
    Last Post: 10-30-2016, 05:50 PM
  2. E46 1999 328i E46 MANUAL 5 SPD PART OUT
    By Cablekid in forum Interior Lighting & Body Parts
    Last Post: 11-03-2012, 02:48 AM
  3. E46 1998 328i e46 need help please
    By frhtr in forum 3 series & Z Series
    Last Post: 10-12-2011, 04:22 PM
  4. E46 FS: E46 BMW Performance Short Shift Gear Lever $25
    By Chad E36 in forum Drivetrain & Transmission Parts
    Last Post: 06-06-2011, 09:06 AM
  5. E46 gear lever problem
    By audi955 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-05-2006, 04:55 PM
