The lock/unlock switch that you lift with your fingers, which is located underneath the gear selector, is not working as designed.
The switch is required to need a slight force to depress prior to being able to select a gear position but mine has no resistance at all. I can select any gear by moving the lever.
I assume that there is a spring which needs replacement and I wanted to know if anyone has done this repair and could share the process or provide a link along with part numbers?
James
2001 740iL Sport
Thanks Shogun
i go to that link but all I get is the following with no instruction.
2001 740iL Sport
You have to download the COMPLETE instructions, this is only page1, there are in total 10 pages with many pics
False alarm re the link. It was my computer that didn't locate the PDF.
Resolved no now I can attack the problem
2001 740iL Sport
