Originally Posted by
NotoriousJJE
Any tricks/ tips on fueling?
Ran a WRL event in the silver car this past weekend and we couldn't get more than 11 gallons in before we had a leak. Not coming from the filler either, Seems like it was coming from the front of the tank somewhere.
anyone have this problem? We lost massive time in the pits and could only run 25 laps/ stop. When we first filled up I did a 32 lap stint. Big difference
You mean Stock tank? There are at least two small vent lines from the passenger side tank to the filler neck. If you yanked those off during the build then that's likely where the leak is.
Look at the filler neck and see if you see two lines going to the top of the tank. It not there's your issue. You'll probably have to remove the tank to fix it although someone else may know better
2002 BMW M Roaster.
1998 BMW 328is SCCA E Production road racer.
