Results 1 to 25 of 25
Thread: 91 535i DME? No start, stumped.
    VA
    91 535i
    I'm embarrassed to come to the Internet and say that my 91 535i won't start, but it won't and I'm stumped.
    i was driving along in town, car running and starting fine, when I started getting an irregular miss at idle, and finally the engine cut off at a stop light. Would not restart with starter (healthy recent battery), but I was on a hill and it did bump start. Drove home on freeway and car ran normally. Pulled in driveway, engine died at idle, has not restarted since.
    so here's what I have done.
    1. Replaced CPS, no change. Replaced fuel regulator, no change.
    2. Fuel: bench tested relay, works fine. Jumpered fuel relay socket and fuel pump comes on and fuel is being pumped to regulator; however still no start. However, when I plug in the relay and turn on the ignition, the pump does not turn on and of course no fuel to the regulator.
    3. Spark: DME relay socket is getting power. Bench tested DME relay, works fine. Tested all fuses front and rear. Pulled distrubutor cap and rotor, look fine. Pulled a plug and grounded it, no spark.
    so, I know the fuel pump works and is delivering fuel to the rail when jumped. But with relay in, fuel pump not on. And no spark. Just for fun I replaced the General Module with a spare, no start.
    DME? Unfortunately I haven't located my spare one yet.
    Any thoughts? And test suggestions?
    thanks!
    Steve
    91 535i
    08 X3
    05 X3
    86 930
    73 TR6
    Jun 2005
    Texas
    E21, E24, E34, E46
    You need to disconnect the fuel return line after the regulator (so the pump has to work against the pressure of the regulator) and observe the flow at this point with the relay jumpered. I don't know the exact flow spec, should be something like a liter in 30 seconds, ie; blasting like a garden hose. It's possible to get good flow with no pressure (input side disconnected) but not get good flow when under pressure.
    The FP relay only engages when the engine is rotating, not just with the key on.
    Have you tried a stomp test? There aren't many useful codes for the M30 but it would probably give a lean mixture code if the fuel pump is going out.
    A bad DME is possible, but not extremely likely. If you have a spare, try it.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    fuel pump details, capacity against counterpressure.... http://www.bimmerboard.com/forums/posts/1256230/
    VA
    91 535i
    Ok, thanks. You confirmed what I thought about when the fuel pump relay gets power.
    removed return line from regulator and there is flow, but very weak. So I just ordered a fuel pump and we will see what happens. Sure is gonna be easier to replace the FP than that %^~*}+{+ CPS.
    Steve
    91 535i
    08 X3
    05 X3
    86 930
    73 TR6
    Oldham UK
    '00 330i Sprt '92 525i
    Pull a plug. If it is wet with fuel then concentrate on the spark side for now. I'm not familiar with the M30 but if it has an HT lead from the coil to the distributor, disconnect it and see if you get a spark off that when you crank. If not, you may have a duff coil or bad connections to it. If that doesn't help, check if the DME relay is actually being energised. Wiring diagrams are here and I think page 1210.2 would be a good place to start:
    http://www.wedophones.com/BMWManualsLead.htm
    Edit: Just noticed you have low flow on the return. It is the flow side up to the regulator which needs the pressure. A new fuel pump won't make it spark
    VA
    91 535i
    Thanks Whisky. I jumpered the DME socket and when doing so could hear a click from the general area of the intake, maybe TPS? But still no start. I'll have a look at the coil today.
    Steve
    91 535i
    08 X3
    05 X3
    86 930
    73 TR6
    VA
    91 535i
    Two other things
    only code from stomp was 1223: temperature sensor. No CEL.
    12 volts present at coil.
    Steve
    91 535i
    08 X3
    05 X3
    86 930
    73 TR6
    Jun 2005
    Texas
    E21, E24, E34, E46
    Quote Originally Posted by whiskychaser View Post
    If you disconnect the supply line, the pump produces no pressure. It's easy for a weak pump to move a lot of volume. If you disconnect the return side, the pump has to work exactly as hard as it does when the engine runs to maintain 45-ish psi. If the volume is sparse on the return side, the pump is definitively bad (assuming it's being supplied with 12v).
    Oldham UK
    Quote Originally Posted by Layne View Post
    What I was getting at is that it is pressure on the flow side which is important. The return is only going to be the difference between what the pump can deliver and the pressure regulator setting. And that is an unknown. TBF, if the FP relay is jumpered and the engine off, I'd expect you to hear fuel flowing through the system though. I just find it very odd to get a fuel pump fail and no spark at the same time.
    OP, you get 12v on one side of the coil with the ignition on. The spark is generated when the other side is grounded by the DME. You can check that when cranking the engine too. But don't go leaning on the HT wires
    Jun 2005
    Texas
    E21, E24, E34, E46
    But you aren't measuring pressure (although that's a good idea too, it's a completely different thing than flow). Considering that the engine isn't running for this test, the flow is 100% equal throughout all hoses of the system.
    Edit: I missed the part where he said no spark. You're right, two failures at once is uncommon. Either he botched the spark test (easy to do, trying to hold a plug on a grounded surface while also cranking the engine). Or he botched the fuel pump test, OR he changed the CPS for another bad one or there's some other reason the DME isn't getting a good engine rotation signal.
    Coarsegold, CA
    91 535i, 2014 528i
    I have the same problem, did you get it fixed?
    Oldham UK
    Have to agree. I'd want take a plug out and see if it was wet with fuel. But before even doing that, I'd use a strobe to check for spark. If there was none at the plug lead, I'd go further back and check it where the HT lead enters the distributor cap and then at the coil itself. We know there is 12v at the + side of the coil, so if there is a pulsing ground on the other side when the engine is cranked, the coil is duff. If not the DME isn't triggering it for some reason. I'm thinking coil because OP was able to bump start it but it would not start on the key. If none of that traces a fault on the spark side, I'd be getting the fuel pressure gauge out
    VA
    91 535i
    New coil, no start. Waiting for FP.
    Put Fluke on new CPS: 553 ohms, which I recall is correct. Put strobe on plug 1, nothing. Also on HT lead, nothing.
    Steve
    91 535i
    08 X3
    05 X3
    86 930
    73 TR6
    Oldham UK
    CPS resistance looks right. Might be a red herring but did you check the air gap? Are you getting a ground at the coil negative terminal when you crank?
    VA
    91 535i
    Ok gang here is the update.
    1. New fuel pump, CPS, coil, rotor, fuel regulator.
    2. Fuel and DME relay bench tested ok, no start when sockets were jumpered.
    3. Battery recent and good.
    still no start. I'm running out of things to replace. Starter cranks great. No spark, 12 v at coil. CPS 550 ohms on 1 and 2.
    last time I drove the car I made it home at 70 mph. Pulled in driveway, bad idle, stalled, never started again. Stomp test only shows 1223. Prior to this, the last thing I did under the bonnet was replace the temp sensor on the radiator a few weeks ago.
    any more thoughts?
    Steve
    91 535i
    08 X3
    05 X3
    86 930
    73 TR6
    Jun 2005
    Texas
    E21, E24, E34, E46
    You're sure about the no spark? And you tested it straight off the coil (eliminating the distributor as a possible cause)?
    Could be that the coil negative wire going back to the DME was somehow damaged.
    Has anyone played with the OBC? If someone sets a code on it, the car will not start. Someone will correct me if I'm wrong, but I believe the starter still cranks in this case, it just won't start. That doesn't explain your bad idle though before the no-start.
    Check if your engine harness connects with a 20 or 25 pin connector (the big round one). There are some differences in the wiring. There are some useless anti-theft functions that you could disable just to eliminate them as a possibility.
    VA
    91 535i
    One concern I might mention is that when I hook up a voltmeter to pin 1 of the socket where the CPS plugs into, I get a reading of 1.2v where I understand I should be getting a reading of 5v to power the CPS. Ring any bells here?
    as for OBC code messing about, no.
    Steve
    91 535i
    08 X3
    05 X3
    86 930
    73 TR6
    Oldham UK
    I think you should have 5V on the black wire from pin 47 of the DME. With the CPS unplugged, check you are getting that when you put your other meter lead on a good ground
    NW suburban Chicago
    hiss by my window
    No spark and no fuel, along with your description of how it died is screaming crank position sensor to me. I know you replaced it but perhaps have defective one. OE part or some e-bay cheapie?
    Mar 2014
    Quezon City, Philippines
    '89 535i/5, '88 735i/5
    I see you changed the rotor, but how about the distributor cap? Doesn't it have posts that the rotor make contact? Maybe they're worn out?
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by cirrusblau View Post
    OR the button could have fallen out but still does not account for no fuel
    VA
    91 535i
    Ok, it runs again.
    the very first thing I did to fix the no start was replace the CPS. I bench tested the new one at 540 ohms, installed it with spec clearance, no start. Then I started looking at all the other possibilities until there was nothing left to do.
    So, I bought a second new CPS, installed it, and the car started right up, runs fine.
    Cars. They are a pain in the ass but we still love them.
    Steve
    91 535i
    08 X3
    05 X3
    86 930
    73 TR6
    Jan 2017
    Amman, Jordan
    1995 BMW 525i Touring
    good job, glad you solved it.
    E34 525i Touring 1995, M52B28 LSD... fully restored.
    Oldham UK
    Good to hear you have it sorted. If it is any consolation, check out conclusions draw here:
    ''Lessons Learned:
    Hall Effect sensors are CRAP. (car is only 55k miles)
    Hall Effect sensors resistance tests mean NOTHING.
    Hall Effect sensors are not completely dead.
    Hall Effect sensors are disposable items.
    Hall Effect sensors are not "lifetime" like sometimes advertised by BMW.
    Never trust anything "lifetime" advertised by BMW.
    Hall Effect sensors are more precise, give a better ignition, and are more expensive''
    https://www.bimmerforums.com/forum/s...-wizardly-help
    NW suburban Chicago
    hiss by my window
    Do us all a favor and call out the brand of that defective CPS.
  1. E28 1987 535is crank no start
    By Stevied535is in forum 1982 - 1988 (E28)
    Last Post: 12-15-2015, 04:42 PM
  2. 91 520i M50--no start--odd voltage on terminal in E-Box
    By b52murph in forum 1988 - 1996 (E34)
    Last Post: 08-29-2010, 01:52 PM
  3. 1989 535i 5spd NO START
    By moving3e in forum 1988 - 1996 (E34)
    Last Post: 02-09-2010, 11:34 AM
  4. 91 535i 5 not starting ??? Fuel Pump ??? HELP
    By uksailmaker in forum 1988 - 1996 (E34)
    Last Post: 05-23-2009, 05:16 PM
  5. HELP! 86 535I Died on Hwy Now No Start
    By dudleyd in forum 1988 - 1996 (E34)
    Last Post: 05-07-2006, 09:51 PM
