Hot topic with these new
CES/STEED twin scroll manifolds.
This could be useful for those building, have built, thinking about building, seeing where u are at, comparing where you should be etc etc.
Those with data logging ability can post logs for those to see.
It would be best to post a short list of build sheet. Hardware can change where your at in the power band immensely.
*Turbo including back housing AR
*fuel type
*rear gear ratio
*cams
*Displacement
*gear tested
Also, for those that would like to request data from a member , just ask. We are here to help.
Here is mine
Dropped the hammer at 2400rpm 4th gear, 20 psi target.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Recorded a video when my car was running to get an idea of where it was, no datalogging yet but
*downpipe/exhaust - 3.5inch dp to 4inch exhaust.
*turbo manifold - custom t3 tubular top mount.
*Turbo including back housing AR - 6764 hx40 t3 .70ar
*fuel type - e85
*rear gear ratio - 2.93
*cams - s50
*Displacement - 2.8
*gear tested - 2nd gear
4100rpm showed 23psi, im sure with the headlamp ram air I could get that down 2-300 rpm.
Can we do a standardized test in addition to whatever other tests people want to do? Like 4th gear steady 2000 rpm cruise, floor it and either log or lift at 3000 and 3500 and note boost at that rpm.
1996 332IS
Built 3.2
Back in my 20's I had a 2nd gen MR2 Turbo and we had a spool comparison thread with requirements. We always did 4th gear, steady at 2000rpm, then WOT. For that model we used the term "spool" to describe when the vehicle made 200wtq (on a dynojet) under these conditions.... i.e. "My car on a GT2860RS spools at 2800rpm" and everyone would know what that meant. Was very convenient. Especially since backhousings, exhaust piping, all sorts of things can change when a car makes a certain amount of boost. Torque is torque.. just harder to get data without a dyno
1996 332IS
Built 3.2
Another standard test might be when do you hit 15 psi in 2nd, 3rd, 4th and 5th from a 2000 rpm cruise on level ground. I'd be happy to do a test but the tests don't mean as much unless we all do the same test. Loggers will be the most accurate of course. The WG spring (or gate pressure if electronic controller) should also be noted because the person opening at 10 psi so he won't exceed 15 psi will spool a little slower than the guy not opening the WG until 15 psi because he is targeting 20 psi peak boost.
Butters, ill post some logs i have from a few cars. I suggest you compile them back in the first thread though like the tq thread..
1989 535i - sold
1999 M3 Tiag/Dove - sold
1996 332IS
Built 3.2
Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
Does everyone agree to this method?
4th gear
Start @ 2k RPM
Stop @ 4k RPM
15 PSI Boost Target
I would say up to 4500 RPM
4500 is for the slow spoolers or to show creep? I expect to be all in by 3500.
Also, do we want 15 psi or 20 psi? Probably the lower number will be one that more people run and those running more could dial back to it.
And again, we have to note the WG spring (or boost controller setting to send the signal to the WG) because the person running a 15 psi spring is probably opening at 10 psi. If I set my boost to 20 psi and open at 15, I should have faster response to 15 psi than the guy opening at 10 psi so he won't go past 15.
I don't understand why people want to stop at a predefined boost level.
If you're looking for spool data, 2500-5000 should be a sufficient window for all types of turbo and gearing (load) setups.
I've used 20 psi for all my testing and logs so far. I also have my boost set higher so that I'm seeing how the turbo, manifold, engine etc interact to affect spool and not how the WG is modifying the curve.
Also, I've mentioned this before that people have to keep in mind that the boost pressure in the intake manifold does not always match the torque available. I may have 19-20 psi at 3000 rpm but the car doesn't start to pull until 3500-4000 rpm. Getting the turbo to spool sooner may not affect the torque curve as you'd think with out doing other engine mods to target the lower cirque curve you desire. Then you would be sacrificing top end power.
2500 to 5000 would be ideal
I think 2500 is too late especially for the small turbo guys. You can see the affects of that on Dyno runs. I agree with staying on it thru a higher rpm though.
That makes sense, then 2k to 5k 4th gear 20psi target
We're comparing turbo/manifold response, not power.
I totally get what you're saying about power though; my ENGINE has 10 PSI at 3k RPM, but I don't feel like I'm making power until 4k RPM!
Would everyone be able to do this with pump fuel?
Just a question....
Dont put a boost target on the test. Just RPM range. 2k-4k in 4th and see where people start making boost. The difference between 10psi and 20psi is going to redundant because of how people have there controllers setup. Manual controllers will take longer to reach target, ect.
But regardless of the controller type, the initial spool wont be effected.
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
