Results 1 to 4 of 4
Thread: DIY: BMW E39 Front Wheel Bearing Replacement (VIDEO)
    Nov 2007
    London, Ontario, Canada
    BMW 733i, BMW 540i/6
    Video tutorial on how to replace the front wheel bearing on a BMW E39. A faulty wheel bearing normally makes a grinding or howling noise when driving down the road. However before it came to that point I managed to catch the problem just by rotating the bearing by hand and will show you once it’s been removed. Beyond being heard, this can also be felt by hand too. It will have somewhat of a grinding feel, not smooth or stiff turning compared to what a new bearing should feel like. This particular vehicle I am working with here today is a 1997 BMW 540i.
    Tools/Supplies Needed:
    -metric socket set
    -metric allen keys
    -johnson bar
    -ratchet
    -hammer
    -round punch
    -brake cleaner
    -interlocking pliers
    -jack
    -axle stands
    -new wheel bearing
    -threadlocker
    -wire brush
    -sandpaper
    -torque wrench
    Procedure:
    -remove the wheel that is affected, safety elevate the vehicle and place the vehicle is on blocks or an axle stand
    -first on the list is removing the brake assembly
    -remove the 2 plastic caps covering the allen head bolts for the slide pins using a standard screwdriver, then use a 7mm allen key
    -remove the cap on the master cylinder reservoir to relieve any pressure when compressing the piston
    -using interlocking pliers, push the piston back
    -use a standard screwdriver to pop off the anti rattle clip
    -lift off the caliper and tie it off using a scrap or bungie cord so it does put added strain on the brake line
    -to remove the brake caliper carrier, there will be two 16mm bolts
    -there will be a 6mm allen head retaining fastener for the rotor, then remove the rotor
    -considering I have Sachs front struts, they are slightly longer than compared to the BMW OEM unit, so the pinch connection on the spindle assemble will need to be loosen and the spindle will need to be dropped down slightly
    -remove the 18mm nut first, the bolt it’s connected to is a 16mm, this bolt will need to be removed to get the connection to separate a little
    -remove the 16mm bolt above the pinch clamp to disconnect the sway bar end link
    -you may need to jack up the spindle assembly to remove tension on the sway bar, the sway bar needs to be disconnected in order to drop the spindle down further
    -now you can push down the spindle assembly
    -unfortunately the wheel bearing flange bolts use high strength threadlocker, heat is normally used to make it pliable but considering it’s close to the strut, I have used brake cleaner instead
    -there will be 4 18mm bolts holding on the wheel bearing, I found a mix between shallow and deep sockets with extensions were needed
    -clean up the mounting surface with some light grit sandpaper to remove any dirt which may cause mounting issues
    -it’s important to compare the old and new spindle to make sure it’s the correct part
    -install the new hub, use one bolt to hold it into place
    -I have already cleaned up these bolts, used a wire brush to remove any dirt and the old red high strength thread locker
    -for this I am using a medium grade thread locker so it can be easier disassembled for the next maintenance interval
    -tighten up these bolts in a criss cross pattern so the flange pulls down evenly
    -torque specs for the 18mm bolts is 75 ft lbs
    -then when you’re ready to push the strut into place, there will be an alignment sticker for the left or right side, align then, use a jack to push it into place and the pinch clamp bolt is tightened to 50 ft lbs
    1994 BMW 740I E32: SOLD
    1984 BMW 733i E23: Hartge engine, Hartge strut brace, Centra type 7 staggered 16" rims
    1997 BMW 540i/6 sport: polished/ported throttle body & traction control unit, E60 short shifter, ss braided flex lines, 2000 M5 tail lights, genuine Alpina bumper lip, genuine M5 auto fold mirrors, facelifted color matched trim
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    FYI, the strut alignment marker could be worn away, if so just score the wheel carrier and the strut.
    Mar 2017
    Lynchburg, VA
    2001 540i
    After pulling the caliper, but before pulling the caliper carrier, break the rotor locating screw loose. A screwdriver inserted in the rotor slots reacts against the caliper carrier, locking out the wheel, making it much easier to break the rotor locating screw loose. Nice video
    2001 Salvage Title 540i
    My build thread: https://www.bimmerforums.com/forum/s...toive-decision
    Holly Springs, NC
    SpecE46, '98 540i Ind
    good video but there are quite a few extra steps that are un-necessary. I just completed this task. Most DIYs say that the upper right bolt is the "troublemaker" bolt but I found the bottom bolt to be hidden behind the strut tube.
    Brian
  1. DIY: BMW E39 Front Wheel Bearing Replacement (VIDEO)
    By ProStreetDriver in forum 1996 - 2003 (E39)
    Last Post: 06-02-2017, 07:37 PM
  2. Replies: 3
    Last Post: 03-07-2015, 02:03 AM
  3. BMW X3 Front Wheel bearing DIY
    By KozanBMW in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-17-2013, 07:47 AM
  4. bmw e36 rear wheel bearing replacment DIY
    By charbel in forum 1991 - 1999 (E36)
    Last Post: 06-14-2010, 09:15 AM
  5. DIY Front Wheel Bearing Replacement?
    By Geo31 in forum 1999 - 2006 (E46)
    Last Post: 03-05-2005, 12:39 PM
