Results 1 to 7 of 7
Thread: how to use voice dialing with my bluetooth phone
    Vermont
    97 328i Vert, 98 M3 Vert
    I just installed a ULF module. From what I've read it has voice dialing built into it. Ok I pressed the sneezing man button on my steering wheel and held it till the display reads PHONE. I said dial Paula since Paula is stored in speed dial. The voice said SORRY. I repeated that with several numbers and it just keeps saying SORRY.
    How does voice dialing work. Step by step please. Yes my phone is paired to the car. I can download the phone book and make calls manually. I want to use the voice dial.
    Vermont
    Well I found a PDF copy of the BMW Voice Command manual.
    http://www.bimmerfest.com/forums/att...8&d=1117201283
    Sep 2012
    El Paso Del Norte, TX, US
    04 M56 e46/3
    In other words, you have to activate the system, then program "Susan" verbally by name an number to the car.
    Having it in your phone's contact list isn't enough.
    If I were to give my Touring a first name, I'd probably name it "Alan".
    Mostly because I like puns.
    Mutual Admiration Society #5
    Vermont
    Quote Originally Posted by Onizukachan View Post
    Correct. If all else fails read the instructions. Of course you have to find them first. Programmed in a few phone numbers. Voice control works great.
    Dec 2007
    Spain
    2003 330ci
    flyfishvt, can I ask what phone you are using to connect to the cars bluetooth? I've had terrible results with various android phones, having to root and change kernel settings to even let it connect. Even though I don't need it anymore as I have integrated bluetooth calling into my in-dash tablet install, I am still curious to what can successfully work with the cars outdated bluetooth module. I hear that iphones don't have the same trouble as android phones.
    Penis,
    Hellmet
    Vermont
    3 year old iPhone5. Pairs up easily and after the initial pairing it connects instantly as soon as I turn on the ignition. I've read that a lot of cars came wired for Car Phone like mine did. The car phone uses a different module. The car phone uses a TCU which can be coded to also allow Bluetooth operation. Im not sure if it allows Voice Control. I removed the TCU and installed a ULF module. The ULF is only Bluetooth. On 2003+ cars the wiring is all there. It needs to be added to VO for the car but that's pretty easy with the correct software. I'm also missing the pairing button. There's an easy fix for that though with a jumper wire.
    I also added factory Aux Port so the only thing I'm missing is Bluetooth/Steering Wheel control of my phone. That's not a huge deal for me. I'm looking for a head unit that looks OEM that doesn't cost $400+
    Dec 2007
    Spain
    2003 330ci
    Yes, my car came with the ULF module but i think anything past android 5 has problems connecting and staying connected. It looks like Iphones don't suffer from this issue. I understand the issue with the OEM look aftermarket headunits, they're expensive and the hardware seems to be lacking even compared to the 2013 nexus 7 which I have installed. That's why I went the tablet route.... its a PITA to set up but it's a fun learning experience and once it's working its a cheap, powerful and expandable alternative. If you are interested in taking this route feel free to pm me for more information.
  1. How to use CarSoft cable with INPA and DIS
    By randomy in forum Diagnostic Software
    Last Post: 08-22-2016, 09:08 PM
  2. How to use Cruise Control on my 89 325is.
    By HOVER in forum 1983 - 1991 (E30)
    Last Post: 03-22-2008, 08:15 AM
  3. How to take good photos with my point and shoot?
    By Garrett M in forum Photography & Multi Media
    Last Post: 09-09-2007, 01:02 PM
  4. How-to use OEM seatbelts with Aftermarket seats?
    By Tanks95 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-05-2005, 10:10 PM
  5. Website to teach me how to use my s45?
    By cleoent in forum Off-Topic
    Last Post: 05-29-2003, 04:54 AM
