Results 1 to 4 of 4
Thread: Any Idea where is BEST to access the final stage unit ?
    Dec 2014
    Houston TX
    BMW X5 2008 3.0
    Trying to replace my FSU on my F10 and getting conflicting responses .... Some say under the hood and on the blower fan and some say under the passenger side dashboard
    On the F10, the final stage resister is attached to the blower motor housing. The blower motor housing is accessed and removed from under the hood on the passenger side near the windshield.
    May 2005
    Houston, TX.
    15 X5, 02 330i, 09 MiniS
    Technically both are correct, but you can only access it to service from under the hood.
    Do yourself a favor and replace the intake filter while you're there, they only last 4-5 years before the foam breaks down and debris gets into the blower housing.
    Tenured Automotive Service Professional - Avid BMW Enthusiast
    Feb 2008
    orlando
    535i
    If you follow the following video, you will be able to get to the final stage unit. in my case i didn't need to change it. While you are in there most likely your foam is also damaged. you can use the following video to get those fixed your self. Remember to disconnect Battery before doing this work.
    How to remove leaves/debri from blower motor BMW F10:
    https://youtu.be/J4HcNS2kvuQ
    How to fix the Blower motor housing with missing foam:
    https://youtu.be/BCVUEqUItok
  1. Replies: 9
    Last Post: 02-01-2017, 12:06 PM
  2. Where is best to drill on compressor for line to wastegate?
    By Bowze in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-08-2010, 03:56 PM
  3. What is best to remove the yellow writing from a part revmoved at a salvage yard?
    By one in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 12-23-2005, 06:52 PM
  4. Where is the Final Stage Unit located?
    By Redgz71 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-05-2005, 06:35 PM
  5. Auto-X Mini Trailer and E36 M3......Where is Best Place for the Tires?
    By jmciver in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-26-2003, 11:51 AM
