Results 1 to 3 of 3
Thread: 88 735i heater issue
    Jul 2010
    Westlake,OH
    1988 BMW 735I
    My 88 735i has a heater problem: All the knobs are on the cooling mode, but heat is coming out of the vents regardless. I took the sword out where I have noticed that a MOSFET is charred, hence only the low and high speed for the blower ( I think this is the reason), but I suspect a heater valve being defective. Is there a procedure to test the heater valve?
    Thank you,
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    http://www.bimmerboard.com/forums/posts/841827/
    how to disassemble the heater valves is shown on my website below, maybe they are dirty and stuck.
    Richmond, Virginia
    '88 735i, '06 RSX
    Could also be bad IHKA module. Replacing the heater valves with a new bosch unit did not fix my situation. Reflowing the solder joints on the IHKA unit helped fix the constant heat problem. Probably the better route is to get a rebuilt unit from ProGrama eventually....for every electronic bit on this car.
  1. '88 735i Sunroof issue
    By CamE32 in forum 1988 - 1994 (E32)
    Last Post: 09-02-2012, 02:40 PM
  2. 88 735i heater issues
    By todd230 in forum 1988 - 1994 (E32)
    Last Post: 01-02-2011, 12:40 AM
  3. next problem 88 735i heater controls
    By jimmm27 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-31-2009, 11:50 AM
  4. 88 735i Trans issues!!
    By tymeboy in forum 1988 - 1994 (E32)
    Last Post: 03-29-2007, 12:12 PM
  5. 88 735i, e32 heater problem
    By slatif in forum 1988 - 1994 (E32)
    Last Post: 11-06-2006, 12:31 AM
