Results 1 to 8 of 8
Thread: DIS is askjng for the cars clearance code
    South Carolina
    2004 330 vert 2004 X5
    I removed the TCU Phone module from my 2004 330 and installed a ULF Bluetooth module in its place. I successfully used DIS to add the ULF module to the ZCS. Now I'm trying to use DIS to remove the TCU. Dis is asking for the vehicles clearance code before it will proceed.
    Anyone know where to find the clearance code?
    Philadelphia, PA
    2005 M3 & 2004 330i
    Just use NCS Expert to do it.
    South Carolina
    Quote Originally Posted by TerraPhantm View Post
    Ok where do I find a list of the 3 digit codes for the different options\modules listed in the VO? All I need to do is remove the one for TCU then write the new VO to the car. I've been searching since last night and I can't find a list anywhere. I've only used NCS once before a long time ago. My learning curve on this is pretty steep even with all the different tutorials online.
    Sep 2003
    Birmingham, UK
    BMW 850 and E55 AMG
    Put your VIN into bmwvin.com and it'll list all your options and the options codes.
    Giftschrank Projekt
    South Carolina
    Quote Originally Posted by enda320 View Post
    Thanks. So the option codes are the same codes used in the VO? Why am I sceptical?
    Jul 2004
    Houston, TX
    36 Cylinders
    VO code = option codes for the most part.
    Better system than the old ZCS.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Philadelphia, PA
    2005 M3 & 2004 330i
    Quote Originally Posted by flyfishvt View Post
    For the most part yes. There can be additional things in the VO that are not option codes, but the option codes otherwise correspond to VO codes. If something is listed as SA205, it will be listed as $205 in the VO
    South Carolina
    Ok thanks. I never needed NCS in my e36. I always used DIS and never felt the need to learn NCS. There is a bit of a learning curve going on but it's starting to sink in.
  1. Here is a stealer in pittsburg pa, $1000 for the car
    By Felixdacat in forum 1988 - 1996 (E34)
    Last Post: 01-29-2007, 07:01 PM
  2. Is running wheel spacers "bad" for the car??
    By KaOTiKM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-31-2003, 03:57 PM
  3. Is over reving the rpm bad for the car?
    By MKit in forum 1992 - 1999 M3 (E36)
    Last Post: 12-07-2002, 01:57 AM
  4. Is redling bad for the car?
    By ///M LIFEŠ in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-30-2002, 12:28 PM
