hi all, i have a 2006 325i that i bought used for my daughter. it came with according to the factory sticker Xenon HID and adaptive headlights. there is no Halo or hi/low beam.Any ideas on the bulb to replace it. Sorry to ask but want to get the right one.
thanks in advance
mike
Mike, I am assuming you have e90 body style? On the e90, you would access light bulbs by removing wheel and wheel well inner splash guard. What I would do if I were you is verify that it is in fact just the bulb you need - swap working side with non working before ordering parts. It looks to me that you have D1S style bulb, but do verify and make sure you have OEM light housings and not some aftermarket stuff (aftermarket may take different bulbs).
I haven't had any issues with Morimoto bulbs that could be purchased through theretrofitsource.com. "Halo" lights are powered separately, here is the link to the bulb I think you need. Do verify part # through realoem.com where you can enter last 7 of your VIN and look through parts diagrams with part #s. Best of luck.
https://www.fcpeuro.com/products/bmw...lb-63117161444
