I have some parts from an S54 engine part out. I listed the mileage next to the part. Please let me know which one you want.
Shipping within the US is included in pricing. I can provide discounts for buying multiple items (usually between $5-12).
Paypal is breakmywallet@outlook.com
Flywheel (200k) - $80 (looks like its been recently replaced)
Clutch disc - $40 (looks like its been recently replaced)
2x Thermostat - $25 (112k)
2x Water pipe (from water pump to heater core) - $15 (67k, 90k)
1x Fan - $20 (90k)
3x Front engine/timing change cover - $25 (67k, 90k, 112k, 200k)
2x Rear main seal housings - $20 (90k, 200k)
2x Oil caps - $10 (90k, 200k)
2x Prs pre-cat O2 sensors – $15 (67k, 200k)
1x Prs post-cat O2 sensors – $15 (200k)
2x Short water pipe section - $10 (90k, 200k)
Power steering pump - $50 (200k)
A/C compressor - $30 (90k)
SMG Left and right engine mounts - $50 (90k)
Crankshaft damper (includes pulleys, bolts, center cover)
Alternator (bolts can be incl for free...its a good idea to have a spare!)
Power steering pump (no pulley)
SMG intake manifold
Oil filter housing
Thermostat, housing, and bracket
Rear main seal housing (I've removed the seal)
SAP Valve
AC Compresser
Starter
Drive belt tensioner
Knock sensors
Water pipe (goes behind thermostat)
Engine mounting plate (goes between trans and back of motor)
Fan w/ clutch
Flywheel
Clutch
Exhaust manifold/header heatshield
Engine brackets (left and right - have an SMG and 6MT set)
EGT Sensor
Water pipe from pump to heater core loop
Picture of the fan clutch with 90K?
