Here is what I have leftover from parting out 3 motors and keeping part of 1. This is most of what you need that attaches to a long block. I’ve priced parts accordingly so you could build an S54 cheaper than buying in pieces than buying a used motor.
PACKAGE PRICE FOR ALL PARTS BELOW - $200 shipped within the US!
Let me know if you have any questions.
Paypal is breakmywallet@outlook.com
Cylinder head parts
1x pr camshafts - $100
1x set follower rods - $30
10x intake valves, springs, retainers - $20 ea
12x exhaust valves, springs, retainers - $20 ea
1x valve cover (hot tanked and clean) - $125
1x set valve cover hardware
1x timing chain tensioner - $50
1x set timing chain sprockets - $40
1x fuel rail - $20
1x intake cam sensor - $20
1x SAP valve - $15
1x PCV - $15
Bottom End
1x set oil squirters - $50
3x oil pump bolts - $10
1x set timing chain guides - $20
1x oil pump chain tensioner - $10
1x rear main seal housings - $10
1x front timing chain covers - $20
1x OE clutch disc - $10
1x crank position sensor - $20
1x pr front O2 sensors - $30
1x set of 3 knock sensors - $50
Accessories
1x left SMG engine mount brackets - $25
1x left 6MT engine mount brackets - $25
1x AC compressor - $40
1x AC compressor bracket w/ belt tensioner - $25
1x power steering reservoir bracket - $10
1x VANOS pressure accumulator - $30
1x VANOS sealing plate - $20
1x water pump pulley - $5
2x idler pulleys (go on end of upper alternator bolt) - $10
1x oil line from PCV to oil pan - $10 (pre-2003/non-AN fitting end and needs rubber hose replaced)
1x fuel/vacuum line to FPR - $10
1x exhaust manifold heat shield - bolts to cylinder head - $10
1x OE fan blades - $10
random question....how much for everything that you don't use? I can come pick up only a few hours away. I need allot of little stuff and probably be easier to buy bulk and sell what I don't use and help save you most of the trouble. you can PM me if you'd like
Shipped price on dampener and the timing gear on the front of the crankshaft. Zip is 93611
dont suppose you have a manual transmission harness?
98 Estoril ///M3 4/6
S54 swap CSL
yeah the trans harnesses are infact different, less SMG wiring on the 6MT
S54 swap CSL
Do you have a good oil pump?
