Results 1 to 10 of 10
Thread: 92' 735il Mustard Relay Replacement Issues (Tail-Light) - solved
    May 2017
    san antonio texas usa
    1992 BMW 735iL
    Hey guys, new member here long-time browser of the forums. I'm really appreciative of all the helpful information I've received off here. Thanks for everyone's time and effort making these boards useful.
    Issue: When I turn on my headlights at night, the Right Rear night-time running tail-light, doesn't illuminate.
    It's not the bulb, I replaced it. It's not the socket, I replaced it. It's not the tail-light assembly itself as far as I can tell, because all the other lights work fine.
    I read all the reports of the Mustard Relay failure being responsible for light issues like this. All the indicators fit my situation.
    I bought the replacement Audi/VW version of the mustard relay that E32 users commonly replace with as a cheaper option than the BMW mustard relay. Here it is-part number 447959875 (electric window control by Hella) It's supposed to serve as a cheaper direct fit.
    I noticed that the prongs on the VW version are different than the stock relay that is in the mustard relay's position currently:
    Regardless, I gave the replacement relay a shot and nothing changed. Still the same tail-light being inoperative.
    Here's the board in my 1992 BMW 735il-
    And this is the empty spot that I put the new replacement relay in-
    Is that even the right spot for the replacement relay?? There's so many different pictures and colors of relays online, it's hard to tell if I'm even using the right relay slot. In any case- the prongs connect and slide in easily enough- just that there's no change in the tail-lights condition, it stays unlit.
    I'm out of options and at my wit's end here as to how to fix this light myself without having to take it to the shop. I know the Audi/VW replacement part maybe not perfect, so I also ordered the stock OEM BMW expensive part as well. More expensive, but it's in the mail on the way.
    I really don't see why the VW relay wouldn't work though. I think I'm missing something here. Can anyone please give me some options here as to how I might fix this? Thanks so much for any help.
    May 2012
    Boynton Beach, Florida
    1990 735I (E32) M30
    Looks like you have the right spot from the boss's fix page http://twrite.org/shogunnew/fixes/mustardrelay.html
    1990 735I (Auto) E32 Feb 1990 to Present
    1996 Z3 Roadster (5 Speed) E36/7 Jan 1999 to Dec 1999
    1983 733I (5 Speed) E23 April 1983 to Feb 1990
    https://www.youtube.com/watch?v=2d4tHoHGaJo
    https://1drv.ms/v/s!Av20xCMMocSsyEpl...h_oOk?e=ekIcAT
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    That does not look like these are the prongs of a mustard relay. What is the exact month and year of production of your car? 1992 is not enough. Use your VIN and check in realoem then select here the correct wiring diagram,
    http://shark.armchair.mb.ca/~dave/BMW/e32/
    also read this thread http://www.7-forum.com/forum/5/musta...ay-221830.html
    The info on my site for that is a bit confusing, it is also for the LKM-L and not only LKM-B. See the headline in the DIY article: Resolder and fix the infamous mustard relay (for LKM-L).There was always a confusion more than 10 years ago when that was changed. The technical info at that time we had was only available for 735 and 750, not for 740 and that document was from 1988. Apparently on the newer LKM this function is integrated into the LKM.
    What exactly is mentioned on the relay you pulled there? p/n etc
    Based on the 1992 ETM you pulled K19 X 51, which is the compressor control relay , that is the ETM for production 9/1991 - 8/1992.
    Also in the 1993 ETM K19 is the compressor control relay.
    1991 ETM shows in that position K7 X60 parking light monitor relay
    So it looks like your car does not have a separate parking light monitor relay and the fuction is integrated into the LKM
    May 2017
    1992 BMW 735iL
    Quote Originally Posted by shogun View Post
    Well as it turns out I was completely wrong. I drive a 1991! Specifically 09/91
    I will read this, thanks.
    Not sure if I have the LKM-L or LKM-B....
    The stock relay I pulled reads- (Bosch 0332014456) (12v 30A) (1378238 167 P (or B?)1) (85 87 86 30) Each side of the relay, respectively.
    May 2012
    1990 735I (E32) M30
    I think you're dealing with one of the orange relays. Check this part number for Mustard or Daylight relay.
    61311378052
    Jul 2016
    Chicago, Illinois
    are slow
    Yea, that car doesn't have a traditional mustard relay. I think you can just pull the LKM out of an E34 and go from there.
    09/91 is MY1992. Coincidentally the same month as the ETM K19\51
    Jan 2005
    Japan
    9/1991 is 1992 model year, so based on 1992 ETM you pulled K19 X 51, which is the compressor control relay , see is the ETM for production 9/1991 - 8/1992. Try another LKM, yours should be a LKM-L, it is written on the LKM what you have, it is next to the CCM.
    Did you check with a multimeter if there is power on the taillight?
    May 2017
    1992 BMW 735iL
    I'll be checking with the multi today.
    Thanks everyone for your help I'm hope by the end of the day I'll have this sorted.
    Jan 2005
    Japan
    May 2017
    1992 BMW 735iL
    Well I fixed the problem yesterday after some thinking and just starting back at the basics.
    It was just a matter of sanding and cleaning the contacts and sockets. There was a lot of corrosion getting in the way of a closed circuit I guess. I checked them all with the meter, and I'm in good shape now. I'm so glad it wasn't a bigger issue.
    After checking them all, I decided to just order replacement sockets and bulbs for the whole tail-light assembly. They were all in pretty bad shape, even though they were operating.
    Thanks so much for the help everyone.
  1. Help: Replacing trunk tail light on 01 33Ci
    By drunkgoose in forum Lighting sponsored by BAVToys
    Last Post: 12-19-2009, 06:46 PM
  2. Any european E91 owners replacing stock tail lights with blackline lights?
    By Tsuma in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 02-24-2009, 04:52 PM
  3. 92 850icomputer dash reads "check rear tail light"
    By coburn in forum 8 Series (E31)
    Last Post: 06-02-2008, 05:45 PM
  4. Who makes OE replacement CLEAR tail lights for BMW E36's?
    By 94calypsored in forum 1991 - 1999 (E36)
    Last Post: 10-03-2006, 12:20 AM
  5. FS:e36 92-98 coupe/2dr stock (Amber) tail lights
    By kirfan in forum BMW Parts For Sale
    Last Post: 09-09-2004, 11:23 PM
