My e46 throws smoke when I downshift ! Like white or blue ish and sometimes black on acceleration! Seems to be running good! Have eBay headers and straight pipe with post cat sensor off
Welcome to the forum!
Well Bluish color smoke would be oil burning, white can be coolant, and black is unburnt fuel. The fact that you have zero exhaust can play in as there is nothing to absorb it, but typically it will be the CCV going bad.
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
+1 likely CCV, but also since you're running catless it's likely nothing if it's a small amount of smoke. Is there any more oil consumption than normal and is there a lot of smoke?
A failing head gasket will give white smoke. Run your finger around your tailpipe, the antifreeze will be sort of slimy. Do a compression test to check your ring wear - smoke under acceleration is rings. Smoke after it's been idling awhile and you step on the gas is the valve guides. CCV's are easy - so it doesn't hurt to start there. CCV's also cause other pressure related problems like a leaking valve cover gasket.
Yes, start with the CCV (Crank Case Ventilation), that is probably what they are talking about.
Darin
Current:
Past:
M-Flight Member
" bluefish white smoke"....LOL and YES...a Striped Bass will have a more black-white hue......well put!
