Results 1 to 4 of 4
Thread: Turns over an fires up but imedietly dies.
    May 2017
    Chandler
    2000 BMW 323i
    I have a 2000 BMW 323i. I redid the head gasket and every other gasket up. In the middle of doing all that all my stuff got stolen so I had to rebuild the motor piece by piece as far as parts. I finally got the car together since there's connected and vacuum hoses all straightened out from what I can tell. Now when I turn the car over it will fire up but dies almost instantly I can't figure it out it's killing me. I just need to know where to look what to test how everything's going it's getting fuel is getting spark and it has compression
    South Carolina
    2004 330 vert 2004 X5
    Do you have a spare MAF you can swap in? If not...with the engine stone cold unplug the MAF and try starting it. If it runs then it's probably the MAF. The problem is that large vacuum leaks will display similar symptoms.
    May 2017
    Chandler
    2000 BMW 323i
    The maf in it is brand new. I went out there just now to try it but the battery is dead so will check tomorrow an update
    May 2017
    Chandler
    2000 BMW 323i
    So I went out there this morning an same thing with the maf sensor unplugged. Then out of nowhere it started up. Ran like shit but it started. I drove it down the road an back. Felt good to drive it. But it had a lack of power. I had to keep the gas pedal to the floor to as actually go. Could it be the timing? I used the tool I had to buy for the vanos set up is there any way I could have gotten it off while putting it on?
  1. car won't turn over afetr jacking up
    By freelancecert in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-16-2013, 04:35 AM
  2. Replies: 4
    Last Post: 04-06-2013, 09:49 AM
  3. Replies: 1
    Last Post: 11-22-2009, 03:06 AM
  4. E30 M3, turns over, wont fire up...
    By MPowered88 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-03-2006, 04:12 PM
  5. 320i firing up but not starting
    By canvey in forum 1991 - 1999 (E36)
    Last Post: 11-29-2005, 05:37 PM
