1995 BMW M3 Turbo Widebody
Shipping can be arranged if needed***
Looks like it's time for an upgrade. This car has been quiet and adventure and lots of fun but it's time to move on! The car holds a clean title and has around 156,000 miles on shell and around 3000 miles on this recent build. Mostly everything that got put on was brand new. Here's the info.
Engine:
-Borg Warner S363 turbo
-Turbo blanket
-Rapid Spool Industries T4 turbo manifold
-Tial 50MM BOV
-Tial 44MM wastegate
-MAC Elenctronic Boost Solenoid
-Ebay intercooler kit with welded pipes(has CES 90 degree aluminum throttle body pipe)
-Ralleyroad 4an oil feed line with vanos bung
-10an steel braided return line
-4" turbo guard
-M52B28 block
-S50B30 cylinder head (resurfaced, cleaned, hot tanked, new valve stem seals)
-ARP Head Studs
-CES Cutring and copper spacer Head gasket(8:5:1)
-80# Deka injectors
-Aeromotive adjustable fuel pressure regulator
-Oil catch can
-Custom metal valve cover
-Valve cover is powdercoated blue
-All brand new gaskets on motor
-New water pump (metal propeller)
-New 75 degree thermostat
- New aluminum thermostat housing
-Rebuilt vanos
-NGK 4554 spark plugs gapped at .025
- New Max PSI ICV hose kit
- New crankshaft position sensor
- New camshaft position sensor
-New knock sensors
- New intake air temperature sensor
-New coolant temperature sensor
- New silicone radiator hoses
- New CXRACING upgraded aluminium radiator
-big electric fan conversion
-Megan Racing engine and trans. Polyurethane mounts
-New AEM Water/Meth kit(haven't installed yet)
Engine Management:
-Megasquirt MS3-PRO PLUG N PLAY
-GM 3 bar Map sensor
Drivetrain:
-5 speed manual transmission
-FX Racing Stage 4 Unsprung clutch kit
- New Guibo
-full shifter bushing overhaul with upgraded delrin bushings
-UUC Short Shifter
- New slave cylinder
- New ECS Tuning steel braided clutch line
Suspension:
- New Megan Racing Euro I coilovers set
- New front sway bar link's
-SPC rear lower control arms(haven't installed yet)
Wheels and tires:
-Ambit RE02's 18x10.5 all around ET25
-Front tires are Sumitomo HTR Z III
255/35r18
-Rear tires are Nitto NT05's
275/40R18
Interior:
-Front seat have been upholistered
-Perfect condition rear seat
-New ///M stripe shift and e brake boots
-New lightweight ///M shift knob
-ATI Gauge pod
-Glowshift boost gauge
-AEM wideband
-New upholistered M-Tech II steering wheel
-///M seat belt Shoulder pads
-JVC stereo deck
-Single Polkaudio 12" subwoofer
-Rear kicker speakers
-Sony 1000W amplifier
Exterior:
-Car has been painted Ferrari Grigio Medio
-Zeemax widebody rear quarter panels
-Felony Form Front overfenders
-Depo glass lens headlights
-black kidney grille's with M stripes
-Euro style tail lights
Exhaust setup:
-3.5" downpipe
-3.5" from turbo back
-Aero Turbine 3.5" muffler
I am missing a lot of other stuff, shoot me a message if you're interested! or give me a call or text at 385-695-0711
List Date: 6/6/2017
For more info, click here to view the original listing: 1995 BMW M3 Turbo Widebody
This item is no longer available.
